Old 08-05-2003, 11:20 AM   #1
russian
russian's Avatar
russian is an unknown quantity at this point
Send a message via AIM to russian
s14 tie rod ends (outer) install help
i need some help guys.
im gonna get my second moog tie rod end tommorow,(they had only 1 ) so....
i have couple questions:
1) how hard to replace? i got manual, so i technically know what to do. is there any catches>
2) balljoint seperator, is it all that needed? cant you just pull it out?
3) it says to lube it, but with what should i use?
oh btw, forgot,
4) im gonna do one wheel at a time, will it cause problems?
I must break you.
russian is offline   Reply With Quote
Old 08-05-2003, 11:22 AM   #2
Dousan_PG
Dousan_PG's Avatar
its easy
basic tools
jack car up adn support it
remove the outer
be sure to get alignment afterwards
a BFH might help to get ball joint part off spindle. you dont need some fancy-pants separator
be careful and work safe.
as far as lubes
some wd-40/liquid wrench for stuck bolt (on tie rod) and that's it
Aaron
Pink GodziRa
Old 08-05-2003, 11:25 AM   #3
russian
russian's Avatar
you da man dousan.
what about jacking? can i work one wheel at a time or both need to be up-in-da-air?
edit:
nevermind, ill just make an extra trip to walmart and get all the stuff i need, after im done ill just turn it back in.
I must break you.
Old 08-05-2003, 11:29 AM   #4
Dousan_PG
Dousan_PG's Avatar
i think its easier w/ both off
then you can turn your wheels left and right w/ no resistance to get better location. and its just much easier that way from my few times doing this. but you can do it either.
Aaron
Pink GodziRa
Old 08-05-2003, 11:33 AM   #5
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
Dousan missed something critical:
GREASE
You need to install the zerk fitting in the bottom of your ball joint and then use a grease gun to shoot grease in there after you install the thing. Keep greasing until it just starts to ooze out. You will need to re-grease about once a year, just to top them off. Oh, and the grease is cheap, but don't forget to buy a gun with a flexible hose at the end of it for reaching tight spaces.
Best way to jack is to do both the fronts at the same time. This way the sway bar won't be putting any undue pressure on the control arms.
Oh, and to elaborate on the removal procedure, just whap it with a hammer to get it out.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 08-05-2003, 11:36 AM   #6
russian
russian's Avatar
sweet. ill get grease tommorow, how much is a grease gun?
I must break you.
Old 08-05-2003, 11:38 AM   #7
Dousan_PG
Dousan_PG's Avatar
grease..i never used any on my Tein endlinks..d'oh. ill check it out
thanks for the heads up!
Aaron
Pink GodziRa
Old 08-05-2003, 11:53 AM   #8
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
brain damge here; grease the what? (i'm trying my best to picture everything down there. gotta get my Kazama's on hopefully this week
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 08-05-2003, 11:57 AM   #9
russian
russian's Avatar
he was talking about greasing inside the rubber bushing u put on and then attaching joint (werent you?? ), mine is damaged so i looked where the grease came out of and its coming from inside the damaged bushing.
I must break you.
Old 08-05-2003, 01:04 PM   #10
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
...just to add another POV, I took mine to the alignment shop and had the guy put them on. I mean, you gotta get it aligned anyway and it's really no problem for those guys to do it. I think I threw them an extra 20 bux.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
Old 08-05-2003, 01:08 PM   #11
Dousan_PG
Dousan_PG's Avatar
my front end alignment cost me 20 bucks....
no use wasting 40 bucks on a job that will take 1 hour at most
Aaron
Pink GodziRa
Old 08-05-2003, 01:51 PM   #12
Replicant_S14
Sure, and it probably only took the alignment guy 15 minutes to do but I put a dollar amount on my time. I would have wasted more money doing it myself.
Some stuff, I won't pay someone else to do even if it is cheaper. Like oil changes.
...like I said, it's just another POV.
Old 08-05-2003, 11:26 PM   #13
uiuc240
uiuc240's Avatar
See the bottom of this end link?
That's the factory SEALED tie rod end. When you buy the new ones, they come with a little zerk fitting that you screw into the middle of the circle that is stamped in the bottom there (the rusty part in the pic). If you don't grease them, they will wear out FAST. But you guys with Tein rod ends might have sealed units...I have no idea.
Eric
