Old 08-05-2003, 04:44 PM   #1
logo20
logo20 is an unknown quantity at this point
j30 help
ok i'm trying to figure this out it was posted by somebody in this board but i don't get it.
With a VLSD with the ABS sensor on the front the trick with the driveshaft is to reverse your driveshaft bolts. i.e. the driveshaft bolts are collared on the diff side i.e. a smooth surface with no threads it is exactly long enough that if you put the bolts in backwards i.e. the collar on the driveshaft side it pulls the driveshaft back just far enough for clearance.
also, how much fluid do i put in the j30 vlsd?
thanks in advance.
logo20 is offline   Reply With Quote
Old 08-05-2003, 06:06 PM   #2
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
FSM says the capacity is 2.5 to 3 US Pints.
I don't understand the quote either. The driveshaft is as long as it is regardless of which way you put the bolts in.
BTW- I installed a J30 diff over the winter and the driveshaft thing wasn't an issue.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
Old 08-05-2003, 06:34 PM   #3
logo20
I just measured the differential and it's 5/8" bigger, i'm thinking of just sticking it in there but i want to know if there is another choice besides cutting the driveshaft.
Old 08-05-2003, 06:39 PM   #4
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
I tilted the diff down by placing washers between the subframe and the mounts at the "nose" of the diff. Seemed to help a bit.
AceInHole is offline   Reply With Quote
