Old 08-05-2003, 07:19 PM   #1
Armysweitzer
Armysweitzer is an unknown quantity at this point
Send a message via AIM to Armysweitzer
s13 New Car help
Hey guys and girls, hope all is well!
I just bought a 1990 240SX Fastback with 80K... Great car with only minor issues. Ill post some pics for you guys to flame my car .
However sitting in my car the other day I turn on my beloved AC which works awesome. When I do that my car shakes and I hear a rattle, Both are intermiten. I look under the car and see a metal thing around the exhaust (resignator ) which is making the rattle.
After I turn it off i get idle surges that range from 500-1500 RPMs that feel like the car is about to shut off. After about 10 seconds they stop and the car is normal again.
Ok Nissan Gods how do I fix this crap?
Thanks a ton for any response and I will post some pics after I get them developed.
Armysweitzer is offline   Reply With Quote
Old 08-05-2003, 11:53 PM   #2
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
not too sure how to FIX it although some noise and unsmoothness from the engine is normal when the AC is on..
take it in if it gets bad
mine does it too..shakes, rattles a bit. AC is a big drain on the motor
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 08-06-2003, 12:28 AM   #3
misnomer
misnomer's Avatar
misnomer has a little shameless behavior in the past
Send a message via AIM to misnomer
that rattling thing sounds like an exhaust heat shield. If it is directly under the drivers seat, it is probably the catalytic converter heat shields rattling.
AC will cause the idle to change on any car, it's more noticable on smaller engines. I wouldn't stress it too much unless it is way out of whack.
Rowsdower saves us and saves all the world!
misnomer is offline   Reply With Quote
Old 08-06-2003, 07:48 AM   #4
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
Could just be a tune up issue. The A/C has an "idle up" circuit. Maybe it's just having a tough time smoothing the idle. It's probably no biggie. If you haven't done it already, tune it up and run some fuel injector cleaner through it. At least then you'll have a base to start from.
I don't know if s13s are the same but my 95 has a real cat, a second cat (that isn't really a cat) and a resonator. The "fake" cat is directly below the drivers seat and it rattles like crazy. It's basically a shell with 2 plates welded inside on the top and bottom. The plates are what rattles. I'm going to fix it by welding up a straight pipe to replace the fake cat all together.
Good luck with the new ride.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
Old 08-06-2003, 08:07 AM   #5
Armysweitzer
thanks a bunch guys. Ill figure something out, its no biggy just i hate rattling noises (im sure you all know what i mean). Yeah the ride is pretty clean i just gotta bondo and paint the rear trunk where i ripped that crappy spoiler off.
Thanks again and pics coming soon.
Old 08-07-2003, 05:56 AM   #6
Armysweitzer
well I was driving around yesterday and I hear that lovely scraping noise. Guess what it was!!!...I get home and see the heat shield barely on my Cat. I had no choice but to take it off. Are there any reasons why this is bad or i should put it back on? THanks a lot
Old 08-07-2003, 06:24 AM   #7
mrmephistopheles
mrmephistopheles's Avatar
just leave it off and don't park on high dead grass after driving.
Old 08-07-2003, 06:47 AM   #8
Armysweitzer
oh jeez .... "officer I swear to god that fire wasnt my fault, Blame Nissan!"
Old 08-07-2003, 12:10 PM   #9
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
i took off my heat shield when i put my exhaust on, not sure why i did it....
but yeah, it really isnt a problem, its not as if high grass is going to catch fire by just only touching your un-heat sheilded area, if it does catch fire, you will be able to drive away faster b/c that mod adds 30hp, and has less drag
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 08-07-2003, 01:18 PM   #10
syco3d
syco3d's Avatar
syco3d is an unknown quantity at this point
Send a message via AIM to syco3d Send a message via Yahoo to syco3d
...you forgot to mention the mAd tYtE weight reduction
Gimme a "A"!
Gimme a "P"!
Gimme a "C"!
What does that spell?
CRAP!
syco3d is offline   Reply With Quote
