Old 08-06-2003, 01:40 PM   #1
gsu240
gsu240 is an unknown quantity at this point
Send a message via AIM to gsu240 Send a message via Yahoo to gsu240
hot shot header, new gasket?
i received my header today and with it came a paper saying i needed to purchase a new gasket, but it came with a gasket, do i need to use both?? thanks for any replies
A one night stand will last until morning, syphilis will last a lifetime.
gsu240 is offline   Reply With Quote
Old 08-06-2003, 02:02 PM   #2
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
If it came with a gasket than you should use that one since it came with it in the package. Sometimes the instructions will tell you that you need a gasket just to make sure you have it in. This is probably because you have a new version and they used an old instruction. By the way does it really remove the cat on your car because im also planning on getting one pretty soon. Also post up the install difficulty and performance gains if you will. Good luck!
SilviaSR20DET is offline   Reply With Quote
Old 08-06-2003, 03:33 PM   #3
ghosts14
ghosts14 is an unknown quantity at this point
I used the one that came with the headers and have not had any problems
GhostS14
-'96 240sx se
-Injen Intake
-OBX SS
-HotShot Headers; Ran. Tech Cat; 5Zigen Border3
-KYB AGX's; H&R Springs
-Whiteline front and rear swaybars
ghosts14 is offline   Reply With Quote
Old 08-06-2003, 03:45 PM   #4
gsu240
can i use the stock bolts with the header?
Old 08-06-2003, 05:40 PM   #5
ghosts14
yep, stock everything
GhostS14
-'96 240sx se
-Injen Intake
-OBX SS
Old 08-06-2003, 11:56 PM   #6
SilviaSR20DET
How easy was the install for you guys with the hotshot header? Also does it remove the cat at all? Any modifications? Or is it a direct bolt on?
Old 08-07-2003, 07:50 AM   #7
gsu240
I am getting the install done today by a local shop, they are only charging $75 for the header, cat and full exhaust.
If you use the stock exhaust i believe it takes away your cat, but i got the random flow cat and 5zigen fireball exhaust.
Old 08-07-2003, 01:07 PM   #8
Agent_S13
Agent_S13's Avatar
Agent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to all
I helped my friend install his HotShot Header last week. It sounds great with his HKS Hiper and downpipe.
To clarify a few things:
1) Hotshot upgraded the header design (maybe 3rd generation) but did not upgrade their instructions. It suggests getting new gaskets but they now include all that is needed.
2) It meets at the bottom and connects to the Cat, it won't replace it. If you want, get a downpipe.... sounds so much better w/out the cat, imho.
We messed around with the install, took us 4 hrs because the hardest part was removing the AIV, EGT, and getting the 10+ yr old bolts loose from the exhaust manifold (PB Blaster works wonders!) Once everything was off, only took 45 min to install the header. We also went parts searching... long story, don't ask. Haha
Don't forget to wipe it down after you install, don't want the fingerprints/grease to burn into the header when it gets hot.
Congrats on the purchase!
-Aaron
'91 240sx coupe
Agent_S13 is offline   Reply With Quote
Old 08-08-2003, 12:02 PM   #9
ghosts14
you don't need to pay somebody to put the headers on for you. It is so easy. You will need to put on a cat before you put on the rest of the exhaust system.
GhostS14
-'96 240sx se
-Injen Intake
-OBX SS
Old 08-08-2003, 05:24 PM   #10
docrice
docrice's Avatar
docrice is an unknown quantity at this point
Send a message via AIM to docrice
make sure if you disconnect the steering linkage to drop in the header you re-align it when you put it on, the whole thing is splined and you need someone to help you find the level position.
docrice is offline   Reply With Quote
Old 08-08-2003, 06:06 PM   #11
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
when i installed mine i didnt have to disconnect the steering linkage. but it would of saved about 10 minutes if i did.
the gasket that came with the header wore out on me. so now im using a MR. Gasket copper gasket. the seal is great and no leaks! i got it a great price of $14 through work. i would suggest using this one if the originals goes south.
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 08-08-2003, 07:05 PM   #12
ghosts14
don't worry about the steering linkage, doesn't really get in the way that much with the new version of the headers. With the old version, it would have been an easier install. The headers will just slip right in once you have all the old stuff out of the way.
GhostS14
-'96 240sx se
-Injen Intake
-OBX SS
