Old 08-06-2003, 11:40 PM   #1
justeno_heat
justeno_heat is an unknown quantity at this point
Send a message via AIM to justeno_heat
SR20 problems opinions helpful
Ok this is what happened. I got my SR running great for 5 days after a long time of hard work. I was driving on the highway and all of a sudden the power shut off. I couldn't get it started so I called the tow truck. They towed it to Pep Boys which was close by for them to work on it. Well they have no idea what an SR is so they didn't touch it. They brought it out and I noticed the turbo downpipe was of the turbo. All the bolts worked there way out and disconnected. So I put them all back and started it. It starts but doesn't run right. It bogs untill the turbo carrys it and smells like it is dumping fuel. I have terrible low end power and it makes whirring sounds. Anyone have any ideas what could make this happen and what I could do to fix it. My friend thinks the A/F mixture isn't right. I think timing. Any idea's?
'91 Nissan 240sx
Redtop SR20DET
Stock T25 8 PSI
Bomex body kit
B&M short shifter
ADR 17" rims
2 10" JL Audio W3's with Kenwood head unit
Erebuni carbon fiber hood
Koyo aluminum radiatior
240 down for the Summer FROWNING
If NISMO stands for Nissan Motorsports, wouldn't Honda Motorsports be HOMO?
justeno_heat is offline   Reply With Quote
Old 08-07-2003, 01:10 AM   #2
DudeYourSoOOJDM
DudeYourSoOOJDM's Avatar
DudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud of
Send a message via AIM to DudeYourSoOOJDM
People run open exhaust all the time...a loose downpipe isn't gonna hurt the way ur SR runs. You might loose a little bottom end but thats it.
Sounds like your problem is elsewhere....
DudeYourSoOOJDM is offline   Reply With Quote
Old 08-07-2003, 01:14 AM   #3
FlyingChicken
FlyingChicken is an unknown quantity at this point
Send a message via AIM to FlyingChicken
check alternator and or battery ground
FlyingChicken is offline   Reply With Quote
Old 08-07-2003, 09:09 AM   #4
christopher
christopher's Avatar
christopher is an unknown quantity at this point
What is making the whirring sounds? Your turbo?
If it is bogging out, you could be running very rich. If you want to confirm this you could check your spark plugs. Assuming you put new ones in( you should have) when you did the swap, they should still look brand new.
Is it bad now when you rev it? Or is it just at idle? I have problems with my idle right now, but it revs fine.
Anyone from the Twin Cities?
http://www.heiruspecs.com/
[email protected]
89 coupe
Red top SR
Blown Stereo....
christopher is offline   Reply With Quote
Old 08-07-2003, 08:17 PM   #5
justeno_heat
It sounds like a lawn mower engine at idle and running and it shakes like crazy. And it was the downpipe that is on the turbo that disconnected not the downpipe that goes to the cat. It literally came off the turbine. Anyway is there a way I can get it to regulate the fuel better. Get it to not run so rich. Because I smell fuel all thruout the car.
'91 Nissan 240sx
Redtop SR20DET
Stock T25 8 PSI
Bomex body kit
B&M short shifter
ADR 17" rims
Old 08-07-2003, 08:41 PM   #6
dvdevo
dvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enough
could it be the injectors? maybe the connectors on the injectors are bad?
dvdevo is offline   Reply With Quote
Old 08-08-2003, 01:22 AM   #7
srJOEYdet
srJOEYdet's Avatar
srJOEYdet is an unknown quantity at this point
Quick story, than I will tell you why it is significant:
I am driving late at night, with a broken water pump. On a short trip, my car overheats to the point that my spark plug wires melt. I burn a lot of oil, and the car starts up fine the next day. As soon as it is warm, it sounds like a motorcycle and has no power. Problem: DEAD CYLINDERS!
You may have a problem with your ignition system. to check this, start the engine and open the hood. Pull your spark plug wires one at a time, and than replace them. Every time you pull a plug wire, your engine should shake a lot, and sound pretty weird. If when you pull one, nothing changes, than you have a spark plug that is not firing. If that is the case, than replace all four to see if it was fouled. Also inspect the plug wires. One other way to test for a non-firing cylinder is to hold a piece of paper in front of your exhaust with one hand, above the muffler. If the paper just bends and stays pretty still, you are ok. If it moves back and fourth, you are missing fire in at least one cylinder.
Joey
Exceed 400x200 size limit
srJOEYdet is offline   Reply With Quote
Old 08-08-2003, 08:32 PM   #8
justeno_heat
cylinder #1 isn't firing. I pulled the plug on the coilpack and it stayed sounding retarded. How do I fix it. I don't know which wires are for the coilpack.
'91 Nissan 240sx
Redtop SR20DET
Stock T25 8 PSI
Bomex body kit
B&M short shifter
ADR 17" rims
Old 08-09-2003, 12:42 AM   #9
christopher
Did you try new spark plugs yet??
If not do it.
What do you mean you dont know what wires are for the coilpack?? They are right on top of the valve cover. You would have had to move them to pull the coil/plug wire.
[email protected]
89 coupe
Red top SR
Blown Stereo....
Old 08-09-2003, 12:45 AM   #10
christopher
I am not trying to scare you, but do you know what a rod knock sounds like? My KA24e had one right before its untimely death. I didn't care because my SR was on the way but...
[email protected]
89 coupe
Red top SR
Blown Stereo....
Old 08-11-2003, 09:26 AM   #11
justeno_heat
Ok my spark plugs are fine. The HKS ones I got look ok, a little black but still ok. I fixed my cylinder problem, some of my wires got melted due to an idiot telling me I have to extend all of my wires instead of only the necessary ones. The turbo melted around 4 or them. So I rerouted them the way they should be and I have a new problem now. All cylinders work now but there is alot of smoke coming from the engine. It smells like gas. Could this just be buildup of the gas that wasn't burned from the cylinder not working before?
'91 Nissan 240sx
Redtop SR20DET
Stock T25 8 PSI
Bomex body kit
B&M short shifter
ADR 17" rims
