Old 08-08-2003, 06:39 PM   #1
thelinja
thelinja's Avatar
thelinja is making a name for him/her selfthelinja is making a name for him/her self
autox w/ busted wheel stud
Would it be safe to autox with only 4 wheel studs on the front pass. side wheel? I busted one a few days ago and it hasn't come in yet at the dealer. The event is tomorrow. Thanks.
thelinja is offline   Reply With Quote
Old 08-08-2003, 07:54 PM   #2
Halz
Halz's Avatar
Halz is an unknown quantity at this point
They shouldn't let you pass tech if you tried.
Halz is offline   Reply With Quote
Old 08-08-2003, 07:59 PM   #3
Dousan_PG
Dousan_PG's Avatar
autozone pep boys etc all have some
yaeh u wont past tech
Aaron
Pink GodziRa
Old 08-08-2003, 09:10 PM   #4
thelinja
thelinja's Avatar
I'm not trying to drag this out, but I would pass tech, seriously. They don't even check that shit around here. Hell, they don't even make me take off my centercaps. Tech here is basically a wiggling of the MC and battery to make sure they aren't loose, then they kick the tires and put the sticker on your windshield.
Old 08-08-2003, 09:39 PM   #5
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
the fact that you SHOULDN'T pass tech should warrant not autoxing unless you can get a stud (really... Pepboys and Autozone carry them. Napa should as well).
AceInHole is offline   Reply With Quote
Old 08-08-2003, 09:55 PM   #6
thelinja
thelinja's Avatar
I decided to just co-drive with my friend. How do I go about changing the stud? I read somewhere about hydraulic pressing?
Old 08-09-2003, 12:22 PM   #7
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
Nah, you don't need a press. Just carefully tap it out. Seriously, like the others said, head to pepboys (or where ever), replace it this afternoon. It's easy. Then you can drive your own car at auto-x.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
Old 08-09-2003, 06:50 PM   #8
thx247
thx247 is an unknown quantity at this point
regardless of what you do- glad you are not driving your car unless you get a stud installed.
thx247 is offline   Reply With Quote
Old 08-09-2003, 09:15 PM   #9
black s13
black s13's Avatar
black s13 is an unknown quantity at this point
Send a message via AIM to black s13 Send a message via Yahoo to black s13
i drove with only 3 studs on my s13 for a few days. the morons at merchants only put 3 on... and i noticed a strange clunking sound at low speed, turns out it was sitting under the center cap, rolling around.
black s13 is offline   Reply With Quote
Old 08-09-2003, 11:42 PM   #10
L.D. 100
L.D. 100 is an unknown quantity at this point
i drove around with one broken (center cap hid it) and then another one broke, and i definetly felt that, not to mention my rear right wheel looked as if it was turning to the right and i dont have hicas, it was horrible. this was in a nice slow street, i cant imagine busting one on a track, youd get ****ed up so bad...
L.D. 100 is offline   Reply With Quote
Old 08-10-2003, 01:23 AM   #11
Zenki_S14
Zenki_S14 is an unknown quantity at this point
In one of my Options video, a guy busted all five studs while drifting on a track. His rear wheel flew off while sliding sideways. He then slams into a wall of tires. Poor guy coudln't get out of his car, cause he busted his doors. haha. Crazy $hit!!! So yeah, i wouldn't auto-x with missing studs. Not worth the risk.
Zenki_S14 is offline   Reply With Quote
Old 08-10-2003, 02:23 AM   #12
VLOWS13
VLOWS13's Avatar
VLOWS13 is an unknown quantity at this point
I used a hammer to hammer out the old stud (if applicable) and then i just pushed the new one in and screwed in a lug nut without the wheel until it settled in the right spot. Easy as that
VLOWS13 is offline   Reply With Quote
Old 08-10-2003, 01:31 PM   #13
drft_180sx
drft_180sx is an unknown quantity at this point
who's that chick in your avatar, shes cute!
drft_180sx is offline   Reply With Quote
Old 08-10-2003, 02:08 PM   #14
zenkiDori
zenkiDori's Avatar
zenkiDori is an unknown quantity at this point
Send a message via AIM to zenkiDori
i just did this a few days ago. go to napa or wherever and get a new stud. remove the brake caliper and rotor, then tap out the old one with a pin or something. if you don't have an impact gun you'll need to take off the hub to pound the new one in. after pounding it in, take some washers or an over sized nut and place it on there before the actual nut. then tighten down to make sure it's in place. put everything back together and Voila!
i drove for days on 3 studs(all were torqued BTW) and even went drifting and was fine. you should be ok to drive as long as the other 3 or 4(i have 4 lug) are all properly torqued down.
zenkiDori is offline   Reply With Quote
Old 08-11-2003, 06:16 AM   #15
adey
adey's Avatar
adey is an unknown quantity at this point
FYI in my experience it's pretty easy to change out your front studs... but the rear studs will likely take some 'encouraging' to take out. I have Nismo 60mm studs up front, but couldn't get any of the rear studs out, so out back it's still stock. Heh heh. xp I should bring those rear hubs to a machine press whatever shop thing.
adey is offline   Reply With Quote
Old 08-11-2003, 02:35 PM   #16
zenkiDori
zenkiDori's Avatar
oh, i forgot to mention, the instructions i posted are for rears. i have never messed with the front.
