Old 09-08-2010, 12:33 AM   #1
DeeJay1337
DeeJay1337's Avatar
DeeJay1337 is an unknown quantity at this point
S14 Brakes lock up. Lock hard. No release.
Ok, I have no clue as to what this is... I'll be driving and use my brakes and they will release only a little bit. And then i'll brake agian and will only release a little bit agian... so now its braking on its own. it will get to a point where teh car will no longer drive. brakes will just lock up.
So i release the fluid on the bleeder and its fine agian until i start braking agian.
I thought this was my front calipers, so i upgraded to brembo's off a g35....then I thought this was a bubble in my brake lines so I bleeded the lines... agian same thing... I thought this was my Brake master cylinder, so i upgraded to a bm57... still same thing!
any ideas?
Car is a 97, KA-T (if it matters) fronts are Brembo calipers from G35 rears are stock...
i bleeded the entire system like 3 times already... I cant get a clue as to what is going on!
A TINT AND DEBADGE IS NOT A FUCKING MOD!
DeeJay1337 is offline   Reply With Quote
Old 09-08-2010, 12:39 AM   #2
iLagX
Trader Rating: (40)
iLagX is an unknown quantity at this point
Feedback Score: 40 reviews
Send a message via AIM to iLagX
brake booster? z32? s14 auto brake booster will help.
iLagX is offline   Reply With Quote
Old 09-08-2010, 01:45 AM   #3
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
Misadjusted push rod from pedal to booster
Hashiriya415 is offline   Reply With Quote
Old 09-08-2010, 01:18 PM   #4
DeeJay1337
DeeJay1337's Avatar
But why would it get misadjusted out of no where? How do I adjust it back?
Old 09-08-2010, 02:20 PM   #5
essforteen
essforteen's Avatar
Trader Rating: (50)
essforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant future
Feedback Score: 50 reviews
Boiling Brake lines from your KA-T manifold?
essforteen is offline   Reply With Quote
Old 09-08-2010, 03:24 PM   #6
Rabboni
Rabboni is an unknown quantity at this point
Did you change the lines when you did the upgrades? Ive heard of rubber lines degrading internally and forming a flap that allows fluid past but doesnt allow it to return. Its rare, and Ive never personally seen it, but it is possible.
Baling Wire-The Duct Tape Of Champions
Rabboni is offline   Reply With Quote
Old 09-08-2010, 04:12 PM   #7
Hashiriya415
Trader Rating: (22)
See there is a lot you need to learn, you need freeplay. Best for you to open up the service manual and get familiar with the brake pedal adjustment procedure. Who knows you might even have something stuck between the pedal, that is not letting it travel all the way back. Might even have some bent parts, you should inspect and adjust. And yes heat can cause fluid to expand, but if correctly adjusted the return valve always stays open letting the fluid go back up into the reservoir.
Old 09-08-2010, 04:41 PM   #8
klits562
klits562 is an unknown quantity at this point
He speaks the truth!
Also im assuming you changed the fluid when you upgraded to the brembos right?
klits562 is offline   Reply With Quote
Old 09-08-2010, 11:22 PM   #9
DeeJay1337
DeeJay1337's Avatar
Its not the boling fluid trust me guys... The turbo doesnt even get hot, trust me its like driving a couple of blocks.
Old 09-08-2010, 11:27 PM   #10
hulkster_s13
hulkster_s13's Avatar
hulkster_s13 is an unknown quantity at this point
pushrod to brake master. the one behind the master cylinder. turn it in like 1.5 turns. same thing happened to me. brakes gradually locked up.
hulkster_s13 is offline   Reply With Quote
Old 09-09-2010, 12:36 AM   #11
driftlife
driftlife's Avatar
driftlife is an unknown quantity at this point
hahahaha the same thing happen to me s14 but mine was a 96 n/a.....i did the same thing you did but they still locked up....it sucked [email protected] just traded it for a s13
driftlife is offline   Reply With Quote
Old 09-09-2010, 12:37 AM   #12
xtopgun32x
xtopgun32x's Avatar
xtopgun32x is an unknown quantity at this point
mastercylinder could be dead. or it could be too weak for your upgrade so it doesnt return the pistons completely. and if the master cylinder is good you could try synthetic brake fluid(assuming youre not using it already) because it could withstand higher temps to prevent boiling from the turbo/manifold heat. ive also seen heat blankets on master cylinders/resevoirs.
xtopgun32x is offline   Reply With Quote
Old 09-09-2010, 12:40 AM   #13
xtopgun32x
xtopgun32x's Avatar
im just saying its really common to upgrade the brakes and shit goes wrong. when you think about it youre putting brand new awesome brake calipers on a 10-20 year old master cylinder. that piece of sh*t is probably worn out..not to mention it wasnt built for z32 or z33 brakes or calipers with at least 4 pistons...
Old 09-09-2010, 12:42 AM   #14
dalers08
dalers08 is an unknown quantity at this point
same thing happened to me. brake booster
dalers08 is offline   Reply With Quote
Old 09-09-2010, 12:51 AM   #15
xtopgun32x
xtopgun32x's Avatar
i keep replying like an ass. but i just remembered when i did a z32 upgrade. i did a bleed at the the calipers and my brakes were tight. then i did a bleed at the master cylinder and with one pump they were magically working. like i said i hate to keep replying but thats what fixed my brake tight issue.
Old 09-09-2010, 12:59 AM   #16
dalers08
Heres what you do. Drive around the block until the brakes lock up again. Pull off the vacuum hose to the brake booster. If the car starts rolling away get a new brake booster.
Old 09-16-2010, 09:18 PM   #17
DeeJay1337
DeeJay1337's Avatar
So... Here's what happens. dalers08 was right. My brake booster is shot. I unplug the vacume line on teh booster and it starts sucking like crazy, (car still on) plug it back in and viola! Car goes rolling easlily.
So my question is now, A new Brake booster, does it matter ABS or not? also years matter?
So here's my upgrade setup for all you to know
G35 Brembo Calipers, With Brembo Solid rotors. SS Brake lines. BM57 and Dot 4 Brake fluid. Rears are just slotted and drilled rotors.
Such a hard thing to get teh 300zx Ebrake assembly and ebrake cables oh such a headache. But its ok! i'll get my rear brembo's too!
Old 09-21-2010, 01:10 PM   #18
DeeJay1337
DeeJay1337's Avatar
Stil need some help, wondering if ABS or non abs brake boosters matter.
Old 09-21-2010, 01:54 PM   #19
endlessboost
endlessboost is an unknown quantity at this point
I dont think it would matter since you've got upgraded brakes. I'd get a z32 brake booster since its dual diaphram. It'll def help with brake pedal feel.
endlessboost is offline   Reply With Quote
Old 09-21-2010, 05:53 PM   #20
projectRDM
projectRDM's Avatar
S14 auto and ABS boosters are also dual diaphragm. 205mm/180mm versus the single 230mm unit found on manual and non ABS cars.
FORMERLY R240NA
