Old 08-10-2003, 06:51 AM   #1
CrispMofo
CrispMofo's Avatar
CrispMofo is an unknown quantity at this point
Turbo kit parts from a Mitsibishi Eclipse
My friend is parting out his 1997 Mitsibishi Eclipse GS-T (FWD) and he'll give me any turbo parts for free.
I'm trying to peice together a cheap kit for my s13.
What will I need to remove from his car to add to my turbo kit collection.
I'm a major newb on turbocharging. So far I have the turbo and side-mount intercooler.
CrispMofo is offline   Reply With Quote
Old 08-10-2003, 09:03 AM   #2
RYAN_S-14
RYAN_S-14's Avatar
RYAN_S-14 is an unknown quantity at this point
Send a message via AIM to RYAN_S-14
TAKE THE INJECTORS I DONT KNOW WHAT SIZE THEY ARE BUT THEY MIGHT BE LIKE 370CC OR SO. RYAN
RYAN_S-14 is offline   Reply With Quote
Old 08-10-2003, 09:24 AM   #3
drifties151
drifties151's Avatar
drifties151 is an unknown quantity at this point
Send a message via AIM to drifties151
take ALL intercooler piping, intake piping, sidemount intercooler, BOV (take to dsm shop and get spring crushed so it can handle more boost, 2g bov sux a d*ck) and flange piping, turbocharger, injectors (might need custom fuel rail, they are 450cc and might not fit into stock ka rail) snag some misc. small hosing and stuff to run vaccum lines to boost controller etc. my old car was built pretty much from a 1g tsi, so all this will def work... it may not look the best but it will def work. good luck!
1995 240sx
drifties151 is offline   Reply With Quote
Old 08-10-2003, 11:25 AM   #4
russian
russian's Avatar
russian is an unknown quantity at this point
Send a message via AIM to russian
hey eclipses turbo is t25 right? is it oilcooled or water?
I must break you.
russian is offline   Reply With Quote
Old 08-10-2003, 11:59 AM   #5
drifties151
on 1g 5spd the turbo was a 14b. on 1g automatics the turbo was a 13b. now as in this case, on a 2g, all the turbos were a t25. now all the of the turbos that came on eclipses/talons are "wet" (water cooled).
1995 240sx
Old 08-10-2003, 12:45 PM   #6
misnomer
misnomer's Avatar
misnomer has a little shameless behavior in the past
Send a message via AIM to misnomer
Make sure you don't rule out the expense of an exhaust manifold, you are still looking at $400-500 for that. . .
Rowsdower saves us and saves all the world!
misnomer is offline   Reply With Quote
Old 08-10-2003, 02:19 PM   #7
drifties151
it doesn't necessarily have to be that expensive. http://www.jgstools.com/turbo/ they have the DIY manifolds for $200 or so. it's cheap but at the same time you do have a quality parts depending on who you get to do the fitment. with a small turbo like the one he is going there shouldn't be any problems. you can also pick up some lines and fitting from these guys too.
1995 240sx
Old 08-10-2003, 05:21 PM   #8
russian
russian's Avatar
i being told quite a few times oil cooled are better, but i tend to think water cooled are safer in terms of spill and leaks. am i right?
I must break you.
Old 08-10-2003, 06:04 PM   #9
CrispMofo
CrispMofo's Avatar
guys, thanx for ya time to clue me in.
it's been helpful.
I wonder if it's cheaper to also take the exhaust manifold from the eclipse, cut the t25 flange off and use it for my custom exhaust manifold fabricated at a exhaust shop.
Is that a good idea, cheaper of worth it?
Old 08-10-2003, 06:36 PM   #10
russian
russian's Avatar
it's been helpful.
I doubt that it would be worth it, just order jgs and let the shop weld it dude
I must break you.
Old 08-10-2003, 07:05 PM   #11
CrispMofo
CrispMofo's Avatar
kewl,
i'll take that advice then.
pfffew.. much easier for me.
Old 08-11-2003, 10:41 AM   #12
drifties151
You can run the dsm turbos without coolant lines. I just ran the oil lines on my setup. plug the coolant line inlet and outlets. all you have to do is be more careful with turbo timing and also the turbo is going to run a LITTLE hotter so you might want to be extra careful with clearance issues.
1995 240sx
Old 08-11-2003, 09:38 PM   #13
jmauld
jmauld is making a name for him/her selfjmauld is making a name for him/her self
Send a message via AIM to jmauld
All of the DSM turbos have oil AND water lines going to them. I don't think that was stated clearly above.
Also, good luck getting the DSM T25 to blow less then 11psi of boost. No one seems to make a wastegate actuator for the turbo that will work at less boost then that. Just be prepared to deal with that boost level and the associated amount of heat it'll make with a 2.4L engine. If it can even keep up.
I think you would be better off with a 14b. You can find those in good condition for less then $100.
Jason
'95 240sx SE
jmauld is offline   Reply With Quote
