Old 10-06-2010, 04:27 PM   #1
dreamin240sx
dreamin240sx's Avatar
dreamin240sx is an unknown quantity at this point
Send a message via AIM to dreamin240sx
ned quick answer please help asap
is an ecu bad if the light comes on. the light on the ecu?
RB POWA!!!!!!!!
dreamin240sx is offline   Reply With Quote
Old 10-06-2010, 04:38 PM   #2
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
nope, just means its on diagnosis mode
R@ddy is offline   Reply With Quote
Old 10-06-2010, 04:45 PM   #3
dreamin240sx
so if it goes off when you roll over the motor does that mean its in diagnosis mode
RB POWA!!!!!!!!
Old 10-06-2010, 04:48 PM   #4
R@ddy
Trader Rating: (32)
huh?
all the way clockwise is diagnosis mode i believe, all the way counterclockwise, is in normal operational mode. just leave it normal dude
Old 10-06-2010, 04:58 PM   #5
94spitfire91
94spitfire91's Avatar
94spitfire91 is an unknown quantity at this point
should be simple use a screwdriver and turn it counterclockwise your green and red lights should stop flashing
94spitfire91 is offline   Reply With Quote
Old 10-06-2010, 05:26 PM   #6
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
Yes! its very bad. Don't drive the car! sell it to someone else!!! and forget about your hobby.
Ilya is offline   Reply With Quote
Old 10-07-2010, 11:56 AM   #7
Rancimo322
Rancimo322's Avatar
Rancimo322 is an unknown quantity at this point
hey quick question!! i swaped the stock cluster no my 90 s13, for the jdm but i dont know what to repin? the od/spd and temp are the only 1s not working ? everything else is great !! the manual only helps so much !
Rancimo322 is offline   Reply With Quote
Old 10-07-2010, 02:53 PM   #8
Ilya
Ilya's Avatar
Originally Posted by Rancimo322 View Post
no my 90 s13
KEEP IT THAT WAY!!! or get rid of your car! Do some research before doing a project and make sure you understand what needs to be done for it to work instead of looking like a fool asking for help once the parts you installed are not working because you had no idea how to install them in the FIRST place. OEM cluster is just as functional as a JDM cluster AND you dont need to re-pin anything! WHAT A CONCEPT!
Old 10-07-2010, 06:49 PM   #9
fufanu180
fufanu180's Avatar
fufanu180 is an unknown quantity at this point
Originally Posted by ilya View Post
keep it that way!!! Or get rid of your car! Do some research before doing a project and make sure you understand what needs to be done for it to work instead of looking like a fool asking for help once the parts you installed are not working because you had no idea how to install them in the first place. Oem cluster is just as functional as a jdm cluster and you dont need to re-pin anything! What a concept!
werrrddd!!
fufanu180 is offline   Reply With Quote
Old 10-07-2010, 07:02 PM   #10
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
Originally Posted by s13_kidd View Post
huh?
You are correct my friend.
Driftphreak87
Okinawandrifter87 is offline   Reply With Quote
