Old 10-07-2010, 10:31 PM   #1
Looseends
Looseends's Avatar
Looseends is an unknown quantity at this point
s13 HELP!!!!! Please help me with a 89 240 problem
i have an 89 s13 and i was switching out my gauge cluster and while doing so i accidentally touched my starter cable which made a small spark, after i installed my gauges my car wont turn over, it wont even activate the stereo or the windows as if im not even turning the key. i changed the starter cable and still nothing. i would greatly appreciate any helps or ideas or tips.
p.s i also installed a new short ram intake the day the problems began.
Looseends is offline   Reply With Quote
Old 10-07-2010, 10:53 PM   #2
mxexux
mxexux's Avatar
mxexux is an unknown quantity at this point
By started cable do you mean starter cable? If so what are you doing messing with that while installing a gauge cluster? Either way it sounds like you burned a fuse...
mxexux is offline   Reply With Quote
Old 10-08-2010, 02:57 AM   #3
Looseends
Looseends's Avatar
my screw driver touched the ignition switch when i was pulling it out of the dash. and i checked and replaced all the fuses and relays and still nothing
Old 10-08-2010, 03:05 AM   #4
Felipe
Felipe's Avatar
Felipe is close to perfectionFelipe is close to perfectionFelipe is close to perfectionFelipe is close to perfectionFelipe is close to perfectionFelipe is close to perfectionFelipe is close to perfectionFelipe is close to perfectionFelipe is close to perfectionFelipe is close to perfectionFelipe is close to perfection
check the starter and battery, checked all fuses relays (under the hood and under the dash)? if you say what you said happend then thats all it should be. my
Late Night Crew #1
Felipe is offline   Reply With Quote
Old 10-08-2010, 03:59 AM   #5
Looseends
Looseends's Avatar
ok ill recheck it all tomorrow and hope for the best i guess. thanks for the tip
Old 10-08-2010, 05:04 AM   #6
Enna
Enna will become famous soon enoughEnna will become famous soon enoughEnna will become famous soon enough
Send a message via AIM to Enna Send a message via MSN to Enna
Disconnect the battery and you wouldn't have had this problem in the first place.
Originally Posted by soreballz View Post
I hoped the candy would make it delicious, but I was incorrect.
Enna is offline   Reply With Quote
Old 10-08-2010, 09:56 AM   #7
davirene
davirene's Avatar
davirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nice
If it was just a fast touch....with a lil spark....then you blew a fuse....if you held it for more then a second then you might of burned up a wire in your ignition...do you have a meter?
1. Main fuse blew....its under the hood in the fuse box....70amp i believe...
davirene is offline   Reply With Quote
