Old 10-14-2010, 05:03 PM   #1
Drifting-pedobear
Drifting-pedobear's Avatar
Drifting-pedobear is an unknown quantity at this point
s14 before the SR goes in, a few things to do.
okay, I've been compromising a list of things that should be done before the SR is plopped into its respective location. please add or comment on the list I've gather this far. tips, info, etc is very appreciated.
Coolant Temp Sensor
Front Main Seal
Rear Main Seal
Water Pump
Intake Plenum To Collector Gasket
Nismo Thermostat
Manifold To Head Gasket
Manifold To Turbo Gasket
Valve Cover Gasket
Spark Plug Cover Gaskets
Intake Plenum To Head Gasket
z32 Fuel filter
All hoses under intake manifold
4 bolt and 5 bolt turbo gaskets
Heater hose
new injector o-rings
PCV Valve
Clutch (pilot/throw out bearing)
resurface fly wheel
Nismo Clutch fork pivot
All belts
i think thats a pretty good list for a well done maintenance job. LMK what else or if you have any comments. thanks
RIGHTWHEELDRIVE.com
Drifting-pedobear is offline   Reply With Quote
