![]() Join Date: Sep 2001
Did my 300zx brake swap, and now i have some questions...
Ok i did my 300zx brake & MC swap today and took it for a drive. I def feel a difference but i noticed after burning in my brakes that i need to warm up the pads before they grip harder. also i don't have abs, there for when i gradually apply the brakes harder and harder, the car doesn't lock up when my foot hits the floor. is this to be expected not haveing abs? but when i jab the brakes hard, the sure lock up quick. one more thing did some 95 se come with a lsd and no abs?
Hrm.... What type of pads are you using?
All can say is make sure you bleed the brakes properly. THe brakes should lock up if you put enough pressure. LSD and ABS were a package. Its either all or nothing. |
#5 |
Just did my swap too, excellent
![]() I've easily engaged the ABS when stopping hard so you should be able to lock the wheels up easily. btw- i didn't upgrade the MS
Current Cars: 1976 Mercedes Benz 300D 1995 240sx SE aka Kate (winner: Best Stock S14 @ 2002 National Convention) http://community.webshots.com/user/jeff976cal If you're interested in parts email me [email protected] |
#6 |
hows your petal feel? mine is rock hard, but i think i might have air in the system because of the loose line, and thats what i think might be causing my petal to hit the floor before the car is either stopped or wheels locked up. def major improvment though. blackfox one question though, does your master cylinder have 2 or 3 lines to it?
#7 |
i swaped to z brakes also and a z MC very hard pedal, then MC was a leaky one got another form the part store rebuilt. it was the cheap one and the pedal isnt as hard and it doesnt leak. but does stop real well stock z pads and rotors, zero brake fade..
240sx s-13 TURBO weekend v-8 killer 90 Talon TSI WARNING.THIS CAR IS EQUIPPED WITH A TURBOCHARGER. DUE TO POSSIBLE BREATHING PROBLEMS UNDER HEAVY ACCELERATION, ALL FEMALES ARE ADVISED TO REMOVE ANY TIGHT FITTING OR RESTRICTIVE CLOTHING FOR SAFETY. |
#8 | |
![]() Join Date: Aug 2002
Ryan |
#9 |
![]() Join Date: Sep 2002
Re: Did my 300zx brake swap, and now i have some questions...
Also make sure you have the calipers on the correct sides or else you will never be able to bleed the brakes correctly and always have air in the lines. The bleeding nipple should be at the top of the caliper. If its not you have the caliper on the wrond sides.
#11 |
yea i just got mine done a week ago, damn those thing stop on a dime...how much did you guys pay for your swap cuz mine came out to about 500 with rotors, lines, calipers, pabs...
'90 240SX w/SR20DET |
#12 |
ok i figured out my problem. when the line was leaking at the fitting it was sucking air into the system and so i need to bleed the system again. as for the mc, it comes down to preference, some say its a bad idea some say its a good idea. personally i wouldn't have done the swap with out the mc. i like how the petal feels. oh and as for my car not haveing abs and having a lsd. i am possitive that i am right. had to do a little testing. but i know i am right. madchild how did you get your soo cheap, were your calipers used? turbo240sx where was you mc leaking from?
#13 |
I got mine fully loaded calipers from AUTOZONE
#14 |
F*uck i should have gotten my calipers from auto zone, i paid like 779 for the full upgrade kit from heavythrottle. whats the benfit of the iron calipers, i thought alum was better because of weight.
#15 |
i got the 30mm aluminum calipers rotors and lines for a total of $417.00 with master cylinder.
#16 |
![]() Join Date: Aug 2003
Ive got skyline r32 gts-t calipers fully rebuilt, Im still in the process of getting everything, by mail they take a while, and does the brake upgrade fit under stock 91 240sx wheels using 5mm spacers?
Ive heard 15s were the last size that could fit? much help would be apretiated Last edited by final act; 08-26-2003 at 04:46 PM.. |
