![]() Join Date: Dec 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Changing ALL fluids in my car
Ok, i wanna change it all, the ultimate tune up. the whole shabang. brake, power steering, trans ect... along with new plugs and wires. what id like from you guys is some advice on the BEST performance brand fluid for each fluid change for the car. and a good set of plugs and wires.... Also... does anyone know where I could find all the proper fluid levels? Thanks for you input!
yes i could use the search, and look. and look. and look. and get treads of arguments, topics sort of what im looking for... ect
![]() or.......... one of you kind souls could give me a quick list. and i would be soooo grateful ![]() ![]() |
#5 |
![]() Join Date: Apr 2002
It all depends on what you want to spend. If you want the best (most money), get Amsoil for the motor and the gears, and throw some Motul in the hydraulic lines.
Get NGK plugs and wires...they're that good. Platinum if you want, but copper is all you need. Gears: Amsoil Series 2000 75W90 gear lube Motor: Amsoil 5W30 full synthetic Brake Fluid: Motul non-race fluid...make sure it's DOT 3, 4 or 5.1...not 5 Power Steering Fluid: Amsoil ATF DEXRON III Coolant: Dunno...Prestone works just fine...buy distilled water to mix OK, now it's time for you to do a little searching on your own bro. I just told you what I would buy (well, actually, I'd just get Valvoline brake fluid...or Castrol GTLMA if you can find it). And any brand of ATF will be fine for the steering too. I have Mobil 1 ATF in mine. Eric
2002 Mazda Protege5 1989 S13 w/SR20DET (sold) Last edited by uiuc240; 08-26-2003 at 11:27 AM.. |
