Old 11-07-2010, 02:59 PM   #1
JTunedMotorsports
Zilvia.net GB Vendor
Trader Rating: (65)
JTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enough
Feedback Score: 65 reviews
Send a message via AIM to JTunedMotorsports
F/S Sr20det s13 shortblock..needs rebuild
look below for thread
JTunedMotorsports is offline   Reply With Quote
Old 11-08-2010, 04:53 AM   #2
JTunedMotorsports
Trader Rating: (65)
need it gone asap
Old 11-09-2010, 09:42 AM   #3
JTunedMotorsports
Trader Rating: (65)
SR F/S sr20det. sr20VE VVL Headsetup,Stock SR20det running longblock...Z32 trans etc
Hey all parts are mine and can verify condition and what not
Feel free to ask me any ?'s if you are unsure about anything
Jim @ J-Tunedmotorsports
will ship if needed
Paypal accepted
Local pick-up is fine along with looking at the parts
60km JDM Z32 transmission ---great upgrade to ppl who want better gearing and stronger transmission.
good condition runs
I pulled off the front cover to machine to work with my sr20det but did no
everything was cleaned and inspected.
you get rear tail shaft seal
front cover gasket
all sensors in bags, bolts , spring ball, rear shifter fork and shifter etc
$550.00
80km sr20det rwd coils all work--was one a stock t25 car
$80.00 shipped
sr20det intake mani
$25.00
HKS EVC5 limited...5k miles..Comes with complete manuel boxes and paper work
best boost controller around..can take out of s13 panel..
$399.00 shipped paypal fees included
65k miles
My personal street car motor..
compression 155-170
No oil consumption what so ever--used Amsoil 10w30
was going to rebuild this but have a stroker motor and dont need this
Motor comes with oil pan to headgasket. starter, alt, ps pit work belts water neck.thermostat
Lower water tubes with coolant temp sensor and hoses (not pictured). Flywheel bolts, trans bolts greddy pulleys installed
this motor runs and pulls great...The only turbo to see it bottom end was a t25 stock car
$1300
SR20ve 1n5 vvl head swap for sr20det rwd.
This pix was before I pulled of the head
You want to rev 9k and not worry about rocker arms here ya go
Notice the rocker arms are positioned on a shaft and are mechanical not hydrolic
For all of you that know this head is the head to use if you want to have not rocket prob and want big ports.
Is head outflows the stock sr20det low port head all day long..No need for porting or cams..
Before the vvl is activated the cam duration is like 240 and when it is activated its around 270-280
This head comes complete with 2 oil activated vvl solenoids, valve cover, gasket, bolts stud bolts, etc
I can get you the intake mani, exhaust mani setup for this to work..tuning etc and tel you how to get it running..I have done a few of these setup for my customers.
$1400.00 obo...I have other parts for this head swap i can include or leave out
Big ports
VVL head
SR20det IAC sensor and knock sensor $50.00 shipped
This is a redtop sr20det head...only used to bottem end off the motor..Head seems ok needs deck cleaning and some new shims and 2 hydro lifters
I would replace the lifters and shims and do a freshenup on this.
$200.00
all 8 rocker arms head small bolts etc
This is a space long block but it needs a rebuild.Crank still seems to be good..My friend overboosted and poped the ring and piston..maybe it can be bored out or resleaved...$175.00u get oil pan to top.
4th Cylinder wall scuffed still cranks
Old 11-10-2010, 10:14 AM   #4
JTunedMotorsports
Trader Rating: (65)
bump..bump
Old 11-10-2010, 01:39 PM   #5
KaminaSan
KaminaSan's Avatar
KaminaSan is an unknown quantity at this point
Can you get me a price for that personal street car motor shortblock shipped to 92507.
If it will lower the price, you can keep the oil pan/pullies/other stuff.
I really just need the shortblock. Thanks!
someone in the car is screaming when that deadly t25 spools up!
KaminaSan is offline   Reply With Quote
Old 11-10-2010, 02:49 PM   #6
KaminaSan
KaminaSan's Avatar
Bump to the top for a very courteous, and helpful seller!
Old 11-10-2010, 06:27 PM   #7
jbretz
jbretz is an unknown quantity at this point
l take the iac and knock sensor
jbretz is offline   Reply With Quote
block, coils, iac, longblock, shortblock, sr20, sr20det, vvl
