11-19-2010, 01:29 AM | #1 |
Sold, please close mods!
Mods, please close thread. Car is sold.
Now for sale or trade for RX7 FD This is my daily driver, located in bay area on weekdays and 95901 on weekends. SMOGGED and passed beautifully on 4/25/11. Only reason I'm selling is because I want an RX7 and need cash for the summer. Price: $8,000 Firm, $6500 w/out wheels 1995 Nissan 240sx Base model, no sunroof clean title 206,xxx miles Manual 5-speed Engine 9/10 All stock KA24DE except for K&N replacement air filter and z32 fuel filter Compression 180psi all four cylinders No check engine light Recently replaced with genuine Nissan Knock sensor and Denso 02 sensor Idles perfect at ~730rpm and drives perfect with ~28mph on fwy A/C, Heater, and PW steering are all there and work great Apex N1 full cat back 3 inch exhaust. lifetime warranty autozone water pump lifetime warranty kragen starter Duralast gold battery Interior 9/10 Black and Gray. All stock also except for front floor lights and a broadway rear view mirror No crack on dash. Very clean dash and panels. Poineer CD player with ipod connect, mp3, etc. Power doors and windows. Everything works. The driverside door won't lock electronically but does so manually with the key and from inside the car. The window sometimes doesn't work unless you give it a little nudge on the arm rest and it then it works fine. Comes with Nardi short hub and no brand quick release Exterior 8/10 Version Select Type 1 Full Kit Nissan Solid Red A54 Paint Job, primer, 4 base coat, 4 clear coat, then buffed, waxed, and polished Front kouki conversion with oem hood, fenders, bumper retainer, headlights, corner lights, dmax clear signal lights, oem USDM Grill Blue HID low beams Rolled and pulled rear fenders Rolled front fenders Have stock trunk while holes filled Have extra stock s14 rear bumper also painted same color as car Shaved antenna Wheel/Suspension/Brake Works VS-XX: Fronts: 18x10+0 225/40/18 Sunny Tires; Rears: 18x11.5+19 265/35/18, rears will need to be replaced soon. z32 26mm front brakes with stainless steel conversion lines z32 rear brakes w/stainless steel conversion lines Full working z32 e-brake setup with R33 e-brake cables Cross and drilled rotors Apex EVX N1 full coilover kit (awesome for DD and track) Powertrix RUCAs, traction rod, toe rods, tension rods Megan rear chasis bar Cusco rear sway bar Godspeed front sway bar Cusco front tension bar Custom/cusco front strut bar Aluminum Subframe spacers Extra Godspeed rear sway bar. Also still have stock front sway bar. Bad: cosmetic stuff small circle cracked in driverside headlight cover but everything functions perfectly. Will come with an extra light with clean clear glass cover. small crack/chip in front bumper which needs to be repair A crack in the front bumper lip but it was refiberglassed. Not straight though but isn't very noticeable. Was in a fender bender but frame is straight, everything lines up perfectly and no airbags deployed. 3 wheels have curb rashes and all could use more love Pictures: After buff and polish and wax pictures by chue240sx - Photobucket ***That is not a rip, just light reflection*** Last edited by Chue240sx; 06-18-2011 at 03:43 PM.. Reason: sold |
11-19-2010, 11:46 PM | #11 |
smart seller....knows he has a clean body so he's selling it before slamming and turbo'ing it, tracking it, then looking like 90% of the cars on here.
"I'm a rage-aholic, I just can't live with rage-ahol!!!" |
11-23-2010, 12:19 AM | #16 |
First off that car is gorgeous.
Would you be willing to do a straight trade (with the turbo) for a supercharged e36 m3? Heres a link to my for sale ad. ksl.com - Car Classifieds for Utah, Idaho, and Wyoming I know it's a good distance between us but I'm sure if you want my car as bad as I want yours we could work something out. Let me know |
11-26-2010, 07:39 PM | #20 |
Mods please change the title to: "Now Selling 95 240sx kouki converted clean DD street legal $9000..Norcal" so I won't have to start a new thread. Thanks.
11-27-2010, 09:47 AM | #24 |
reason i rose the price is b/c after reassessing everything and other people's car and how much they're selling for I believe I should raise the price. But if it's too high, then price is back to $8000 firm.
11-27-2010, 03:29 PM | #25 |
11-27-2010, 05:48 PM | #27 |
If you read his ad you would see he is selling a turbo kit with it...
Im jusssssss saaaayyyyin...
TW: http://zilvia.net/f/cars-sale/390459...d9s-coils.html |
