Old 12-02-2010, 05:59 AM   #1
rhyderofthastorm
rhyderofthastorm's Avatar
rhyderofthastorm is an unknown quantity at this point
Send a message via AIM to rhyderofthastorm
DIF Thermostatic Dual Electric Fan Controller Ver. D
Up for sale is my still in plastic DIF Fan controller, Version D 10090. I originally got this before I got my aem ems, and found out that the ems controls my fans as well. Thus, I don't really need it anymore. It's still new, here's some info I got from frsport's website:
The DIF 10090 Dual Fan Controller Ver. D programmable unit utilizes a digital microprocessor to precisely control the electric fans on your vehicle. The unit features two fan outputs that can be independently adjusted to turn on at a user selectable point via rotary switches. This allows the user to turn on each fan only as necessarily, freeing up horsepower and increasing throttle response.
The DIF Dual Fan Controller Ver. D utilizes the factory OEM 2-wire coolant temperature sensor on the engine for precise and accurate measurements. Supported vehicle manufacturers are pre-programmed into the unit with calibrated sensor values to ensure that sensor measurements translate into accurate temperatures. Coupled with a microprocessor, this results in consistent on/off fan control.
Integrated relays simplify wiring and provides up to 12 amps of current per output and 25 amps total, reducing extra costs and installation time.
Additional features:
* Ignition input to turn unit on and off
* Manual input and A/C input to turn on both outputs
* User programmable to engine make or universal sensor
* Improved cool-down logic with 30 sec. maximum limit
* Dual detented rotary switch to prevent accidental adjustments
* CNC 6061 aluminum anodized case for improved thermal dissapation
* Includes necessary hardware and wiring
The DIF Dual Fan Controller Ver. D is compatible with these manufacturers: Acura, Honda, Mazda, Mitsubishi, Nissan, Infiniti, Toyota, Lexus, Ford, Chrysler, Chevy. The controller also provides support for 2-wire sensors with operational voltage range between 0.4V - 2.8V
Asking $110
I'm asking $110 since it's unused and still has everything it came with. the box itself is only a little dirty from laying around.
Local Pickup only, I'm located by Rio Hondo and South El Monte. lmk!
-Richard
Well, he’s kind of had it in for me ever since I accidentally ran over his dog. Actually, replace “accidentally” with “repeatedly” and replace “dog” with “son.”
Last edited by rhyderofthastorm; 12-02-2010 at 08:00 AM.. Reason: Title adjustment
rhyderofthastorm is offline   Reply With Quote
Old 12-04-2010, 04:54 PM   #2
rhyderofthastorm
Le Bump #1
Old 12-06-2010, 10:51 PM   #3
rhyderofthastorm
El bumpo #2
Old 12-06-2010, 11:37 PM   #4
robbie2883
robbie2883 is an unknown quantity at this point
i'll taKe it if you'll ship
robbie2883 is offline   Reply With Quote
