Old 12-02-2010, 10:13 AM   #1
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
Injector choices for GT2871R .64...
Question: I am upgrading cams and head gasket and am wondering what I should do about injectors...
- Should I just buy some side feed 740cc injectors and run the stock rail
- Should I consider buying a JWT top feed fuel rail with STi top feed injectors (will they work?)
There's a reputable local company that sells injectors on an exchange basis, which makes it very affordable. They offer them with the documentation for the flow matching and modifications...
Injectors : Kito Auto Sport Online Store
Context: (Current configuration)
Stock internals 94-96 S13 Blacktop SR20DET
Megan bottom mount manifold
7 layer exhaust gasket, nord locks, copper lock nuts and stainless studs
New GT2871R .64 AR
Apexi suction kit for 2871/z32 MAF
z32 MAF
Enthalpy tuned ECU
Stock intake manifold, TB
STi 550cc injectors
Greddy Elbow
Greddy downpipe and 3" Invidia catback
Greddy FMIC
Greddy BOV
Next week I will be adding:
Reworked head with 3 angle valve job
New Greddy springs
New Brian Crower Titanium retainers
New BC 264 12.00MM lift cams
Stock cam gears
New Aeromotive 13109 FPR
New Tomei -6AN adapter to stock fuel rail
New Push-lock Aeroquip -6 AN lines
Yet to buy:
Apexi 87x0.8 metal head gasket
ARP head studs
Intake and other gaskets
Advice?
Seraphim38 is offline   Reply With Quote
Old 12-04-2010, 11:56 AM   #2
Prok0
Prok0 will become famous soon enoughProk0 will become famous soon enoughProk0 will become famous soon enough
Send a message via AIM to Prok0
I'd just do 740s in a stock rail, less shit to change, less headache, no real benefit of going top feed.
Also, you may want to invest in some better cams, or cam gears. BC cams are generally off the centerline compared to the cam card, so they need to be degreed in to make the most power, and with the money/time your spending on cam gears and degreeing them in you could probably just get some good JWT or Tomei cams.
Prok0 is offline   Reply With Quote
Old 12-04-2010, 12:12 PM   #3
Seraphim38
Seraphim38's Avatar
I got a deal on the head with Greddy springs, BC cams & retainers, valve job all done already. I was planning on JWT, Tomei or HKS stage 2s but the deal on the head was too good to pass up.
Thanks for responding to the thread. I am guessing that most people would say to stay with the stock rail and buy some flow matched 740 side mounts...
Old 12-04-2010, 12:23 PM   #4
homeslicej2
homeslicej2's Avatar
homeslicej2 is making a name for him/her selfhomeslicej2 is making a name for him/her self
I'd order Mazworx's headstud kit. It's still ARP material, just made to their length specs for the RWD SR20DET & are only a bit more the ARP's kit. Mazworx's ones seat fully into the block. Check out their website for a comparasion.
homeslicej2 is offline   Reply With Quote
Old 12-05-2010, 01:41 PM   #5
jspaeth
jspaeth's Avatar
jspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfection
I am running Tomei 740s and they seem to work just fine.
Daily driven
jspaeth is offline   Reply With Quote
Old 12-05-2010, 02:12 PM   #6
nismoman
nismoman is an unknown quantity at this point
+1 for 740 sidefeeds
nismoman is offline   Reply With Quote
Old 12-06-2010, 09:34 AM   #7
Def
Get 740 cc injectors. I was maxing out my 525 cc STi sidefeeds pretty easily.
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 12-06-2010, 09:57 AM   #8
Sasquatch13
Sasquatch13's Avatar
Sasquatch13 is an unknown quantity at this point
My friend took his sr20det too Jeff Evans he had nismo 740's and jim wolf c1 cams. His injectors where maxed out at 380rwhp / 330tq. Car is sick nasty fast, but Jeff Evans said top feed injectors is more efficient an that he could squese more power out if he had top feed. Plus they are cheaper ( the injectors them self not so much converting over the fuel rail ).
If your not planning on going super high power like over 400rwhp then I would just stay side feed. Hope this helps!
Sasquatch13 is offline   Reply With Quote
Old 12-06-2010, 10:04 AM   #9
s14freak93901
s14freak93901's Avatar
s14freak93901 can only hope to improve
go for 740's. maybe one day when you decide to go larger you don't needa get another set of injectors.
s14freak93901 is offline   Reply With Quote
Old 12-06-2010, 10:25 AM   #10
Seraphim38
Seraphim38's Avatar
I just bought an HKS top feed rail from another board member and am going to get some 740 or 800 top feeds. I know that the top feed rail isn't necessary, but I don't want to buy side feeds now and have to upgrade to top feeds later; I would rather buy the better unit now and not have to replace it later.
Thank you all for your responses, and I will definitely be buying the Mazworks head stud kit...thank you for that feedback as well.
