Old 12-06-2010, 04:53 PM   #1
cutter
cutter is on the path to ruincutter is on the path to ruin
Send a message via AIM to cutter
Hks gt 2540 might be a gt 2540r very comparable to 2871r
I have an hks gt2540 it is ballbearing so i think it is a 2540r. this is a direct replacement for the sr20det. it is very comparable in size to a gt2871r.
The HKS GT Series Turbos are based on ball-bearing Garrett units and like the HKS Signature Series have re-engineered compressor and turbine wheels along with specific A/R and trim levels. All GT Series Turbos are designed to be a perfect blend of power and response. HKS achieved this balance by first choosing to use a ball-bearing center cartridge to reduce friction along with an off-center turbo design for improved efficiency and flow. Next HKS carefully tested Trim and A/R levels along with different inlet and outlet diameters to achieve optimal power. The results of this combination are turbos that not only deliver amazing power, but also spool incredibly fast.
COMPRESSOR: gt2540r
-Wheel- 46 Trim - 51.7 Inducer / 76.2 Major
-Housing- 60 Inlet / 50 Outlet - 0.50 A/R
TURBINE:
-Wheel- 76 Trim - 53.8 Major / 47.0 Exducer
-Housing- GT25 inlet / Internal GT25 oulet - 0.64
-Retail- $1980
GT2871R
Ind Exd Trim A/R
49.2mm 71.0mm 48 0.60
Wh Dia Trim A/R Type
53.8mm 76 .64 Wastegated
only $800 call chris @ 903 530 9214 or email me at [email protected]
turbo is in excellent condition, it only has a few thousand miles on it.
cutter is offline   Reply With Quote
