Old 12-12-2010, 08:09 AM   #1
hasnain608
hasnain608 is an unknown quantity at this point
91 hardtop 300zx twin turbo for sale!!
mods:
installed the new apexi AVCR boost controller BLACK EDITION!!!! currently boosting at 14 psi because nyc road are shitty but with the newly installed boost controller just change to setting A and u will be boosting at 18.1 psi or further
Intake-AshSpec Doolz-Twin JWT Pop Chargers-Samco Boost pipes -Twin HKS SSQV (Recirculated)
MegaZ Radiator Air-Guides-Z1/Howe Upgraded Radiator-Z1/Earls Upgraded Oil Cooler-Nismo Upgraded Thermostat-A/C Delete-AMS Waterpump overdrive pulley-Stock tt fan(stock fans always work the best)
Motor-95+ 615cc Fuel Injectors-300 Degree Fuel Rail w/ Specialty-Z SS Braided fuel lines-300 Degree EGR Delete-AshSpec Massive Side Mount Intercoolers 2.5" I/O-Unorthodox Racing Underdrive Pulley-
Z1 GT600R BB TURBOS
-Stainless steel oil feed lines-Engine Gasket Kit (replaced ALL gas-Engine Gasket Kit (replaced ALL gaskets and seals)-New OEM Oil Pump-Heads Acid bathed, and decked with valve seat resurfacing-Valves resurfaced-OEM block acid bathed and honed-All freeze plugs replaced-OEM lower manifold cleaned and sandblasted-Ford Solid Rubber Motor Mounts
Exhaust-
Specialty-Z 5-bolt Supersplit Downpipes-AMZ Performance Testpipes-Specialty-Z Catback Non-Resonated Exhaust
Drivetrain-
RPS Segmented Flywheel-RPS Max 6 Puck-Nismo Transmission Mount-AMZ Performance 1pc Driveshaft-Stainless steel braided clutch line
Suspension-Ground Control Coilovers (350f/400r)-Koni Adjustable Shocks-SPL Subframe Spacers-SPL Front Camber Arms-SPL Rear Camber Arms-Powertrix Adjustable Tension Rods-Stillen Adjustable Sway bars-Energy Suspension Steering Rack Bushings
Brakes-
Brembo Drilled and slotted rotors (front and rear)-HAWK HPS pads-Stainless steel braided brake lines
Wheels and Tires-
TT Rear (245) Wheels-Bridgestone Potenza S-03 Pole Positions(225/50/16..245/45/16) (500)
Engine Control/Diagnostics-AshSpec ECU-AEM Oil Pressure gauge-AEM Water temp gauge-Detonation Sensor Relocation-PTU Relocated under nose panel
Interior-
Alpine Headunit w/ Ipod Adapter-Rockford Fosgate Dual 6x9's-3 DIN Gauge Pod-Red Stitched Shift knob-Red Stitched Shift boot-Red Stitched E-Brake boot
COSMETIC MODIFICATIONS:-99 Jspec Taillights-CPark Fog Light Intercooler Ducts-TT Rear Flushmount Wing-99 Jspec front bumper-Sportmax 962's 18x9.5 in rear and 18x8.5 in the front-Brand new kuhmo ecsta SPT tires
bad: front bumper needs to be repainted
price is 9.5k firm! no trades please, selling because im moving to manhattan(nyc) and need to get rid of car.
hasnain608 is offline   Reply With Quote
Old 12-12-2010, 12:01 PM   #2
hai1206vn
hai1206vn is an unknown quantity at this point
Was it an N/A converted to turbo?
Nice car. I just moved to NYC area 2 months ago and I hate driving here.
hai1206vn is offline   Reply With Quote
Old 12-13-2010, 08:57 PM   #3
SidewaysTaco
SidewaysTaco's Avatar
SidewaysTaco is an unknown quantity at this point
free bump for sexy white z.....sell me your wheels!!!!!
89' Nissan Cefiro
INSTAGRAM
SidewaysTaco is offline   Reply With Quote
Old 12-13-2010, 11:20 PM   #4
wrestlingandrunning
wrestlingandrunning is an unknown quantity at this point
Nice Z! Bump for fellow Z owner
wrestlingandrunning is offline   Reply With Quote
Old 12-16-2010, 06:47 PM   #5
hasnain608
yea the hardtop also known as slicktops only came in n/a it was converted into a tt and was built upon that
Old 01-06-2011, 06:36 PM   #6
hasnain608
sold delete thread
Old 01-06-2011, 06:59 PM   #7
SidewaysTaco
DID WHEELS GO WITH IT???? if not lmk.
89' Nissan Cefiro
INSTAGRAM
