Old 12-12-2010, 10:11 PM   #1
Ruff Ryder 6
Ruff Ryder 6 is an unknown quantity at this point
S13/KA Garage Sale
I need this stuff gone from here and out of my garage. I will work with the price and shipping on most of this stuff. PM is the best way to get a hold of me. So here we go:
KA24DE T3/T4 turbo manifold $old
Steering wheel $old
Manual Transmission crossmember and mount $old
Manual side mirror, passenger side, no mirror (easy replacement) $5
S13 valve cover $old
S14 distributor and pigtail $40
KA24 ACT six puck clutch disc (unsprung) roughly 3k miles on it $75
Same disc as here
KA24 clutch kit six puck sprung NA applications less than 5k miles on it $old
S13 KA speedometer sensor, tested works $old
S13 door lock timer $5
S13 power door wiring $10 S13 seat belt controller $5
KA24E ignition coil $20
Z32 30mm aluminum calipers $old
DOHC powersteering reservoir and steering rack lines (with high pressure hose) $old
S13 power mirrors $20 each Passenger side $old
Coupe tail light housings $25 each pair with bulbs $15 without. 1 PAIR $old
S13 sun visors $5 pair
KA24 A/C compressor (condition unknown) $30
Power window regulators and motors (working when removed for manual windowed track car) $25; drivers side sold
Steering wheel $old
S13 SOHC throttle cable $old
S13 toe arms (bushings still good) $15 both
S13 traction arms (bushings good) $15 both
KA24DE fuel rail $10
S13 non-ABS master cylinder (7/8" worked great) $15
S13 koni housings (save time hacking up yours, for ground control/custom coil over setup) $old
S14 housings (used with ground control setup, and Bilstein damper, weld ring already in place above the tire) $30
Ruff Ryder 6 is offline
caliper, clutch, manual, steering wheel, turbo manifold
