Old 12-21-2010, 09:44 PM   #1
kyro1282
kyro1282 is an unknown quantity at this point
KA No start, and lost at this point...
I have a 94 240sx se with a stock ka. I am having an issue get it to start, I had the starter and battery checked and boyh passed, i bypassed the clutch switch which finally got it started. But I drove the car down the road to the gas station and shut it off, when I tried to start it, it wouldn't even turn over let alone click or anything. The starter relay will click when I try to fire it but that's about it. I'm out of ideas as of where to go next, any and all help will be greatly appreciated. Thank you
kyro1282 is offline   Reply With Quote
Old 12-21-2010, 09:56 PM   #2
j20accord00
j20accord00's Avatar
j20accord00 is an unknown quantity at this point
Send a message via AIM to j20accord00
Check your grounds. Make sure they are all clean. Then clean your positive terminal. Clean your pos terminal on the starter too and clean the trigger wire on the starter. If that doesn't help my guess would be its the starter..happened to me and drove me insane!
92 Coupe ka-t
j20accord00 is offline   Reply With Quote
Old 12-21-2010, 10:08 PM   #3
kyro1282
Now I took the started to advanced and had it tested and it's just where it supposed to be amps wise. All the terminals are clean at all connection points as well. Could it be anything to do with the relay or ignition switch?
Old 12-21-2010, 10:12 PM   #4
fueled by hate
fueled by hate is making a name for him/her selffueled by hate is making a name for him/her selffueled by hate is making a name for him/her self
you should test the starter signal wire going to the starter and test the ignition switch.
fueled by hate is offline   Reply With Quote
Old 12-21-2010, 10:19 PM   #5
kyro1282
This is where I get a bit foggy, how do I check both of those?
Old 12-21-2010, 10:24 PM   #6
fueled by hate
grab a meter and check to see if you get full 12v at the ignition switch when you turn the key to on. Check the constant 12v power and check to see if the starter signal wire gets 12v when turning to the key to the cranking position. Then test the signal wire on the other end at the starter. My friend had a short in his starter signal wire and I had to run a new one for him.
Old 12-22-2010, 09:50 PM   #7
kyro1282
Alright I checked the voltage on the started signal wire and I have the 12v. Now I'm lead to the ignition switch but im not 100% where to start, I mean I know where it's at I just have no clue how to check it; any suggestions?
Old 12-23-2010, 01:18 AM   #8
fueled by hate
on the back of the switch (the oppossite end of where the key goes in) you will see where all the ignition wires are connected. Use a meter and make sure all the ignition wires get full 12v when they are supposed to. Also check all your fuses with your meter.
