Old 12-23-2010, 02:03 PM   #1
shinobis13hb
shinobis13hb's Avatar
shinobis13hb is an unknown quantity at this point
how to tell if you have a bad turbo gasket?
well to make it pretty simple..
when i am in boost i hear a screaming sound coming from my turbo i think..??
im not sure.
my exhaust hangers broke the other day and my exhaust started to scrape the ground i could just imagine how much stress that would cause on all the gaskets.
id like to somehow try to figure out my problem before jumping into the situation. and changing the turbo OR the gasket.
im afraid that it could be my turbo going out but i have seen threads of it just being a bad turbo gasket.
shinobis13hb is offline   Reply With Quote
Old 12-23-2010, 02:11 PM   #2
hartig
hartig is an unknown quantity at this point
when my gasket went bad, it was pretty obvious.. there were chunks of the gasket sticking out of the turbo>downpipe connection
hartig is offline   Reply With Quote
Old 12-23-2010, 02:15 PM   #3
chiboy002
you should be able to hear it, or open your hood and rev it while holding your hand near it. Air should blow out
Also, wouldn't psi not hold with a blown gasket?
street dancer.
GLEAM
Old 12-23-2010, 02:19 PM   #4
codyille
codyille's Avatar
codyille is an unknown quantity at this point
Same thing happened to me, In my case the bolts that mount the exhaust manifold to the turbo had backed out and created an exhaust leak that made a screaming sound.
codyille is offline   Reply With Quote
Old 12-23-2010, 02:52 PM   #5
shinobis13hb
thats what i am thinking. i dont hear a leak though. i will go check right now if i feel air. more feed back would be great. i dont see any metal gasket anywhere.
Old 12-23-2010, 03:52 PM   #6
TheRealSy90
TheRealSy90's Avatar
You usually won't see the gasket if it blows out. Sounds like the gasket to me, i've blown 3 now and they all do the same thing.
Such a good signature.
Old 12-23-2010, 06:28 PM   #7
shinobis13hb
i put my hand next to all the gaskets. the elbow gasket from the compressor is bad. so that would explain the noise correct? that would also create a sort of boost leak right? or turbo lag?.
Old 12-23-2010, 09:01 PM   #8
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
^Yup, good luck with it. It won't spool for shit with that leak. that's really the most important one. If you replace it and don't want to use the locking plates, conical top lock nuts work great because they can take the heat without backing off and those plates get a little annoying to get back on/off.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 12-23-2010, 09:20 PM   #9
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
i put a new 4 bolt gasket and tack welded the nuts on the turbine housing
R@ddy is offline   Reply With Quote
Old 12-24-2010, 06:58 AM   #10
nismoman
nismoman is an unknown quantity at this point
you can weld it, and that works, and alot of people do that.......I use these cooper lock nuts they work great and you dont have to grind to remove them.
FRSport Turbo Outlet 8mm (1.25pitch) Locking Head Nut
nismoman is offline   Reply With Quote
