Old 12-23-2010, 03:08 PM   #1
blake110491
blake110491 is an unknown quantity at this point
s14 Ka24 tranny problems
Only grinds in second randomly a few times a day and its annoying the hell out of me.Thinking about doing a rebuild for it but having trouble finding sources for that if anyone one can help me out...or if there's any upgrades available that are worth doing,much appreciated
blake110491 is offline   Reply With Quote
Old 12-23-2010, 03:13 PM   #2
SnakeKack
SnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of light
Send a message via AIM to SnakeKack
Hows the fluid? Or your clutch and slave cylinders?
SnakeKack is offline   Reply With Quote
Old 12-23-2010, 03:32 PM   #3
Couped_up'd
Couped_up'd's Avatar
Trader Rating: (47)
Couped_up'd is an unknown quantity at this point
Feedback Score: 47 reviews
2nd gear is like the most common to go out. Just replace it with another good ka24de tranny.
Couped_up'd is offline   Reply With Quote
Old 12-23-2010, 04:20 PM   #4
blake110491
The fluid is good but not sure what kind the previous owner had in...But that definitely came to mind since it was a lot more frequent when it got cold.Seems pointless to replace it with another used one when this one still works fine...Was wondering where i could pick up a rebuild kit? By the way i was planning on replacing the clutch whenever i tear the tranny down and check it out, its life is coming to an end soon
Old 12-23-2010, 05:09 PM   #5
chiboy002
same shit happened to me, i was told it was the pilot bearing. Could also be the syncro's going out of alignment
My 1st and Reverse syncros are bad so it takes a long time to get into reverse or first on occasion
street dancer.
GLEAM
Old 12-23-2010, 04:42 PM   #6
csar
csar's Avatar
csar is an unknown quantity at this point
First check your clutch master cylinder fluid or if its leaking from the inside were the pedal is at.then check the slave if its leaking also.have you changed your transmission fluid?does it only grind when its cold?maybe get thicker fluid....if it grinds weather its warmed up or cold then its your 2nd gear syncro going out.
csar is offline   Reply With Quote
Old 12-23-2010, 05:06 PM   #7
blake110491
I'll throw it up on a lift and check it out thanks
It won't grind everyday but it's noticeably worse when its cold, still grinds whether its cold or not though
Old 12-23-2010, 06:52 PM   #8
blake110491
My reverse sucks to get into, its been like that with every car i've owned.So does anyone know where to buy a rebuild kit at or what? lol
Old 12-23-2010, 07:55 PM   #9
93nismo
93nismo's Avatar
93nismo is an unknown quantity at this point
it would be cheaper to just get a trans that is known to be good then to rebuild it. i don't suggest the rebuild unless you plan on keeping the car long enough to justify it. either way you'd have to pull the trans out so id just buy another transmission and throw it in. you can always sell or rebuild the one you have now and still drive the car. or you could just deal with it, my trans grinds in 1st 2nd and 3rd. i just live with it. changing the fluid might help a bit, theres a thread somewhere on here with some good info on different fluids. it seems amsoil(i think) is the best. i have yet to try it. don't use royal purp.
WTB: 1/24 scale chuki s13 model.
93nismo is offline   Reply With Quote
Old 12-23-2010, 08:16 PM   #10
csar
csar's Avatar
Also try bleeding your clutch.it's free unless you don't have fluid it like what $2,3 dollars
