Old 12-24-2010, 02:02 AM   #1
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
upper part of intake manifold removal!!
hi i have a s13 sr20 and have a coolant leak coming from the coolant hoses under the manifold so i decided to replace them and just gonna remove the upper part but cant seem to get it off and dont know why!!got all the wiring off and all the nuts and bolts but cant see whats holding it down.any considerations??
angel mkiv is offline   Reply With Quote
Old 12-24-2010, 02:06 AM   #2
Slidin' Sam
Slidin' Sam's Avatar
Slidin' Sam is an unknown quantity at this point
Well, assuming you DO have all the nuts and bolts off, you are probably getting hung up on some coolant/vacuum lines or something. It has been a VERY long time since I have taken apart a s13 sr, so my memory is somewhat, if it was a s14 sr I could help you a lot more, lol Just take a look around from all angles possible and use a flash light to take a good look everywhere.
Slidin' Sam is offline   Reply With Quote
Old 12-24-2010, 12:05 PM   #3
angel mkiv
angel mkiv's Avatar
ive been looking for ever already now and felt around every runner for a connected hose and nothing!!other then the 2 nuts and 3 bolts on the bottom half, 2 nuts and 6 bolts on top,and the bolt holding that vaccum hose connected to the intercooler what other nut/bolt is there?
Old 12-24-2010, 12:22 PM   #4
angel mkiv
angel mkiv's Avatar
ive been looking for ever already now and felt around every runner for a connected hose and nothing!!other then the 2 nuts and 3 bolts on the bottom half, 2 nuts and 6 bolts on top,and the bolt holding the vaccum hose to the intercooler.is there anything else?
Old 12-24-2010, 12:25 PM   #5
zeromechanic
zeromechanic is an unknown quantity at this point
I had problems with mine also, but the upper manifold will not come off unless you undo the lower manifold also, they come out at the same time, they are put in at an angle so just undo all the bolts for the lower and it should come off with a little wiggling.
zeromechanic is offline   Reply With Quote
Old 12-24-2010, 12:27 PM   #6
chiboy002
maybe the previous owner used some silicone for a gasket (seen it happen) and it's just hard to take off. But first, steal your sister/mom/gf's make up mirror and run your hand through the top/bottom and look for bolts
street dancer.
GLEAM
