Old 12-24-2010, 10:14 PM   #1
MJenkins1101
MJenkins1101 is an unknown quantity at this point
Spacers
Hey guys Im gonna be using This Kit on my 92 coupe with stock fenders and 17x7 wheels what size spacer should I run for flush appearance.
MJenkins1101 is offline   Reply With Quote
Old 12-24-2010, 10:26 PM   #2
lakaiae86
lakaiae86 is an unknown quantity at this point
whats the offset??
lakaiae86 is offline   Reply With Quote
Old 12-24-2010, 10:27 PM   #3
RedSiBaron
RedSiBaron is an unknown quantity at this point
Originally Posted by lakaiae86 View Post
whats the offset??
that really is the million dollar question isnt it...
RedSiBaron is offline   Reply With Quote
Old 12-25-2010, 12:27 AM   #4
MJenkins1101
Well I'm going to be entirely honest, sound stupid, and go ahead and say whats offset?
Old 12-24-2010, 10:27 PM   #5
lakaiae86
kinda a weak size...imo
Old 12-28-2010, 04:13 PM   #6
MJenkins1101
Sorry I didn't reply sooner. My offset is +40 mm
Old 12-28-2010, 04:21 PM   #7
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
jesus, ideally a x9+15 is imo the perfect wheel size for an s13 on stock body. (i know some of the fitment gurus will disagree but from what i have seen it looks pretty good and requires just a roll and pull)...sooooo with that being said you need (again in my humble opinion in regards to fitment) a 25mm or a 30mm i would just spend the 100 bucks on the psm kit as you can run either size with it.
sidewaysil80 is offline   Reply With Quote
Old 12-28-2010, 04:23 PM   #8
MJenkins1101
Awesome, thank you so much for the advice i really appreciate it. =)
Old 12-28-2010, 04:35 PM   #9
nismoman
nismoman is an unknown quantity at this point
+1 for psm spacers. You will deff need 25 to 30mm to look decent
nismoman is offline   Reply With Quote
Old 12-28-2010, 05:22 PM   #10
MJenkins1101
So i googled PSM Spacer kit and I couldn't find what I think I was looking for, can someone please point me in the right direction?
Old 12-28-2010, 05:34 PM   #11
nismoman
POWERED BY MAX:
Old 12-28-2010, 05:42 PM   #12
MJenkins1101
Awesome thank you.
Old 12-28-2010, 09:14 PM   #13
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
Honestly, you'll need like 50mm of spacer... I'm running an x9+22 on my s14, which has a little bit of a wider fender, and I still want 20mm spacers to make it +2 effective...
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 12-28-2010, 09:28 PM   #14
S14_drift junkE
S14_drift junkE is an unknown quantity at this point
for the OP, here is 9.5+15 on my stock bodied 13...
not the best pic, but it gives you an idea. its pretty much flush, little tuck/poke. To achive this look (if thats what you want/going for) you'll need 57mm more. so i guess a 50mm spacer. http://www.1010tires.com/wheeloffsetcalculator.asp <---- for all your wheel offset calculation needs/questions
S14_drift junkE is offline   Reply With Quote
Old 12-28-2010, 09:32 PM   #15
MJenkins1101
thats basically what i was looking for thanks..thats a huge spacer :/
Old 12-28-2010, 09:21 PM   #16
Drifting-pedobear
Drifting-pedobear's Avatar
Drifting-pedobear is an unknown quantity at this point
id say about 70mm spacers with a 30mm over fender, and possible a good stretch like, a 145/35/17...
if you want to be illist that is...
RIGHTWHEELDRIVE.com
Drifting-pedobear is offline   Reply With Quote
Old 12-28-2010, 09:39 PM   #17
S14_drift junkE
imo, youre better off not getting the kit...yet.. and/or save up for better wheels.
Old 12-28-2010, 09:49 PM   #18
MJenkins1101
I like the kit, I already ordered it. Also like the wheels and they are already installed :/..ill try them both out for a while and see how i like them, if in a few months im not happy ill make a change.
Old 12-28-2010, 09:52 PM   #19
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
S14 Drift junkE are those staggard or just 9.5 all around?
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 12-28-2010, 09:54 PM   #20
S14_drift junkE
9.5 all around
Old 12-28-2010, 10:19 PM   #21
Touge Whore
Touge Whore is an unknown quantity at this point
Since you have already ordered the spacer kit and have the wheels, just drive it as is for a bit. See how the fitment is with the alignment you want, then save for rims that will have the offset you want to no longer need spacers. Use the calculator to see how the rim width and offset will affect clearance.
I punch b*tches for gold nuggets...
Touge Whore is offline   Reply With Quote
