Old 12-27-2010, 11:18 PM   #1
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
who has a redtop sr with a s15 turbo ?
I have a s15 turbo ready to go in, and im wondering if I use the s13 t25 inlet and outlet pipes what hotpipe I will need to use, the s14/15 one or the s13 one ?
I do not want to use the adapter plates, as I already have the s13 hotpipe and have access to a s14/15 hardpipe.
sorry if this has been covered, when I searched the topic came up with the results of what is needed for a s15 turbo or selling a s15 turbo but nothign really on what hardpipe to use with the t25 inlet/outlet pipes on the spec r gt28 turbo.
Old 12-28-2010, 01:15 PM   #2
slim
slim's Avatar
slim is an unknown quantity at this point
i just finished installing my s15 spec r on my redtop and found out that it is going to pretty much be a custom install. i haven't found anyone selling a conversion hot pipe yet. basically you need about 2 inches before the 90 degree bend cut off the t25 hot pipe (the 90 that is right off the turbo) and weld a 45 degree bend in place. or just cut off the 90 and use a silicone 45 but i think that looks crappy. hope this helps.
slim is offline   Reply With Quote
Old 12-28-2010, 02:25 PM   #3
nismoman
nismoman is an unknown quantity at this point
i dont really understand what you are asking. if you use the reclocking adapter plates then all the s13 stuff works with it. hotpipe intake everything....
nismoman is offline   Reply With Quote
Old 12-28-2010, 02:42 PM   #4
Wake
Wake's Avatar
That was a horrible fucking response.
FRSport T28 Turbo Upgrade Installation Kit SR20DET
or
Let me google that for you
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 12-28-2010, 04:37 PM   #5
Big Zee
Big Zee's Avatar
not really wanting to use the clocking plates. I just want to know which hotpipe to use if I use the t25 outlet pipe on a s15 t28 turbo. will it be the s14/15 hotpipe or the s13 one ?
Old 12-28-2010, 05:36 PM   #6
nismoman
Absolutely not the s13 one unless it can be modified
Old 12-28-2010, 06:07 PM   #7
Big Zee
Big Zee's Avatar
alright s14/15 hotpipe it is! thanks guys its all I needed
