Old 01-02-2011, 01:58 AM   #1
ticklemeermuel
ticklemeermuel will become famous soon enoughticklemeermuel will become famous soon enoughticklemeermuel will become famous soon enoughticklemeermuel will become famous soon enough
Send a message via AIM to ticklemeermuel
Toyota Soarer Badge, SC300/400 K&N Filter, 2jz stock man Rear Subframe, Short shifter
just like the title says. I have a bunch of leftover s13/ 240 things I need to get rid of. I have pictures of some of the stuff, if not posted check back.
-Toyota Soarer Badge $30 picked up
-K&N Drop in filter for an SC300, SC400 $40, or $50 with the stock airbox. Went NA-t so I have no use for this.
-Stock 2jzge exhaust manifold with cat, works great passed smog. $80
-S13 SR20DET REDTOP includes WEBB design 262 Cam shafts with a head gasket leak, between cylinder 1&2. I ran this setup a couple years back with a gt2871r. I started parting it out so its missing small things crank pulley, valve cover. Change the head gasket and you have a long block good to go. When I did the compression (approx 2 years ago) test these were the numbers, warm. 119, 125, 145, 147 $400 OBO
-S13 Rear Subframe no upper control arms, Fairly New (5000 miles, never tracked) ES bushing kit all around. I'll include the Aluminum Subframe Collars with this purchase (SPL, I believe). $250
-Short shifter, looks like a C's brand, came off a front clip. Decided not to use it. $80
-s13 power mirrors $40 for the pair
-s13 coil pack cover $25 shipped, $20 picked up
thanks for looking. Contacting me with any questions!
-Erm
[email protected]
AIM: ticklemeermuel
ticklemeermuel is offline   Reply With Quote
