Old 01-02-2011, 08:44 AM   #1
JSpecBnr32
JSpecBnr32's Avatar
JSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud ofJSpecBnr32 has much to be proud of
Send a message via AIM to JSpecBnr32 Send a message via MSN to JSpecBnr32
HUGE CLEANING OUT THE GARAGE SALE V.1!!!!! s13/s14/r32-- KA-SR PARTS!! APEXI D-MAX!!!
City: lynnwood
State/Province: wa
Price: varies
Item Description:
SO ALL PRICES ARE OBO AND PICS ARE UPON REQUEST.
LETS START OUT WITH THE S13 PARTS!!!!!!
-S13 manual drive shaft............................................. ........$60
-2 stock s13 fuel pumps with pick up socks...........................$20 each
-s13 center drive shaft bearing carrier bracket........................$10
-2 pairs of stock s13 tie rods inners.....................................$25 a pair
-s13/s14 clutch master............................................ ...............$20
-2 s13/s14 slave cylinders......................................... ................$10 each
-s13 headlight plugs for flip up or silvia headlights..........................$5
-s13 Clutch Pedal............................................. .......................$40
-s13 Manual Brake Pedal............................................. ..............$20 SOLD
-s13 gas pedal............................................. .......................... $15
-ka24de and ka24e alternators....................................... ............$30 each
-ka24e starter........................................... ..............................$30
-z32 s13/s14 fuel filter practically new.........................................$5
-s13 drivers side power mirror............................................ .........$20
-s13 brake booster........................................... ........................$20
-s13 DOHC ka24de lower harness........................................... .....$20
-s13 SOHC MAFS w/plug setup to run either BLOW through or normally...$20
-s13 DOHC ka24de Power Steering Reservoir..................................$20
-3 s13 Manual Tranny Speed Sensors..........................................$ 40 each
-2 s13 rear view Mirrors........................................... .................$15 each
-s13 power antenna Complete.......................................... ..........$20
-s13 radio/shifter bezel............................................. ................$20
-Brand new ka24e or ka24de lower radiator hose...........................$20
-2 s13 silvia JDM BLACK LEATHER GLOVE BOXES, looks way cleaner...$40 each
-s13/s14 manual tranny mount............................................. ......$20
-s13 USDM climate control with A/C............................................$20
-s13 center heat vent removed from dash no cracks......................$20
-2 black s13 center consoles.......................................... ...........$20 each
-2 s13 Steering Racks............................................. .....................$40 each
-s13 ka24e water temp sensor that goes on lower radiator hose with pipe...........$5
-2 sets of complete 240sx hatch tail lights...................................$50 a set
-s13 lower under dash panel............................................. ..........$20
-2 s13 Hatches with Glass 2 have holes from factory wing one doesn't all have glass intact............................................ $50 each
-2 rear coupe glass............................................. ..........$50 each
-Drivers side 240sx hatch quarter panel glass....................$40
-2 rear coupe bumper covers..........................................$3 0 each
S14 PARTS!!!!! AND R32 PARTS!!!!
-skyline r32 fuel pump.............................................. ................$40
-r32 skyline complete mechanical speedo cable w/ free cluster thats missing tach.................$50
-r32 rear brake rotors same as z32 still plenty of life left................ $40
-s14 stock RUCAS, TOE RODS, and TRACTION RODS......................$20 a pair
-s14 brake booster with master cylinder installed...........................$40
-s14 SE Factory Electric Fan works on any S-chassis.....................$30
-JDM s14 RHD steering column w/ignition and key came off a clip......$60
-s14 E-brake handle............................................ .....................$30
-s14 radio brackets w/tray thats screwed on................................$30
-s14 black glove box............................................... .................$20
-s14 Cluster bezel trim.............................................. ................$20
SR20DET PARTS!!!!!!!!!!
-2 s13 sr20det t25 turbo outlets........................................... .....$20 each
-Complete s13 sr20det SMIC set with piping clamps and Side mount...$100
-s13 sr20det water inlet and outlet............................................ .$20 each
-sr20det Exedy Stage 2 pressure plate very new used on daily driver.....$80
-sr20det water pump pulley............................................ ...........$20
-sr20det clutch fan............................................... ...................$35
-s13 sr20det IACV off of a redtop............................................ ...$50
-sr20det alternator w/bracket........................................... .........$40
-sr20det brand new OEM rear main seal still in package...................$15
-nice sr20det K&N CONE AIR FILTER bolts onto MAF.......................$50
-upper sr20det radiator hose.............................................. ........$5
-s13 sr20det or ka24de(e) HKS drop in filter for airbox.....................$30
AND A COUPLE RANDOM AFTER MARKET PARTS AS WELL!!!!!
-2 Infiniti 6x9's Kappa Speakers $100 a piece new..........................$80 for the pair SOLD
-2 Infiniti Reference Series 4x6's 135w peak, w/ built in tweeters......$50 for the pair SOLD
-Action Racing Universal Hood Dampers/Props came off my Z pretty cool....$50
-JRE Oil Catch Can with 3 ports and quick drain comes with hoses...$40
-MotorSport 60mm Tach with 8k Redline and single black gauge pod......$40
-350z Passenger Side Lower Control Arm........................................$70
-OEM 180sx kouki Right JDM circle turn signal..................................$20
-OEM 180sx kouki bumper left side bumper/fender peice....................$40
-T3/T4 Turbo Blanket super nice keeps temps way down!..................$30 SOLD
-s13/s14 to z32 rear Stainless Steel Project Silvia Brake lines brand new still in package....................$80
-Mazda After market Steering Wheel Hub, MOMO and NARDI bolt pattern......$20 SOLD
-great working condition Apexi Blow Off Valve, Twin Chamber and adjustable sound. Comes with Flange welded onto a 2ft long 2.5" aluminum 90 degree pipe that can be used on your Intercooler pipe setup............................$90
it is this same exact one
-Authentic DMAX Euro LED 180sx crystal Clear Tail lights paid over $450 these look similar to HippoSleek for those that can tell the difference. Yes these have real LED circles that light up. None of that Ebay Altezza Garbage. Be the Cool new kid on the block with these taillights ...................................$350 or will trade for a clean set of Kouki 180sx tails
Call/TXT = 425-760-7339 and like i said pictures upon request.
myspace.com/sx_drifter
JSpecBnr32 is offline
