Old 01-02-2011, 10:06 AM   #1
Autobacs
Autobacs is an unknown quantity at this point
Sr20det tps resistance test
Guys I just did a resistance check on my TPS on my SR using the S14 SR20DET FSM (harness unlugged, resistance check on pin B and C on 3 pin type TPS while manually turning throttle).
Per the FSM, resistance should be around 0.7 K ohms when released and 5 K ohms when thottle is depressed with range of 0.7 to 5 K ohms when halfway.
What I got was 4.8 K ohms released and 0.68 K ohm when depressed. Completely opposite to the FSM.
Is my TPS toast or is the FSM wrong?
Autobacs is offline   Reply With Quote
