#1 | |
It's Always Broken.
![]() Join Date: Feb 2010
![]() Feedback Score: 14 reviews
Boost leak tester question:
I made a boost leak tester from a PVC end cap and a valve stem. I apply pressure via the turbo inlet. (http://www.vfaq.com/mods/ICtester.html)
I was wondering if I need to disconnect my wastegate line during this process, and I also need to know if this pressurizes the whole intake manifold as well? Because wouldn't the pressure just go out the exhaust if it pressurized the intake manifold..? (Since some valves are going to be open in the head) If I do need to disconnect the wastegate line, would I remove the wastegate end of the hose, and just crimp the hose in half with vice grips or something..? I tested for leaks up to 20 PSI and I didn't have any, but that was with the wastegate line attached. Do I need to block off my valve cover breather(attached to pre turbo intake) and idle air hose (attached to cold pipe) as well?
Man w/ CTSV & a Car Seat
Just pressurize it and listen carefully for leaks. Having a gauge built into the test helps alot so you know the system is still pressurized. I usually use simple green and spray it everywhere (couplings, lines, TB, etc). That way you can also clean shit up when your done.
![]() Join Date: Sep 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
I took the intake pipe off the throttle body and bought a pvc cap and blocked it so the air isnt going into the intake manifold.
I used a bike pump that had a gauge built in haha I used soap and water to watch for bubbles. same thing as the simple green method ![]() |
