Old 09-08-2003, 10:50 PM   #1
SiNFuL
SiNFuL's Avatar
SiNFuL is an unknown quantity at this point
Send a message via AIM to SiNFuL Send a message via Yahoo to SiNFuL
Question Pass. Headlight goes up slower than Driver side...?
Hey guys, my pass. side goes up slower than my drivers side. It happened a little after I install my toggle switch for "cheaP" sleepy eyes. Sometimes if I leave the switch on "ON" long enough they both go up at the same time. I don't think my motor/hydraulics oif the light are bad; just the signal. Are there any radioshack parts I can use to increase the signal strength to my pass. side headlight?
-Galen
"Wherever You Go, There You Are."
SiNFuL is offline   Reply With Quote
Old 09-09-2003, 09:50 AM   #2
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
flux capacitor?
old_s13 is offline   Reply With Quote
Old 09-09-2003, 12:26 PM   #3
SiNFuL
SiNFuL's Avatar
im an idiot for electronics, so what does that do? Sounds good and smart. hehe.
-Galen
Old 09-09-2003, 12:46 PM   #4
91CRXsiR
91CRXsiR's Avatar
91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self
Send a message via AIM to 91CRXsiR Send a message via MSN to 91CRXsiR
i think thats what makes time travel possible,
but you need 1.8 gigawatts.. GREAT SCOTT !!
91CRXsiR is offline   Reply With Quote
Old 09-09-2003, 01:05 PM   #5
mrmephistopheles
mrmephistopheles's Avatar
jeeez... it's 1.21 gigawatts (pronounced jiggawatts)..
i'd suggest eliminating the toggle switch and see what happens.
Old 09-09-2003, 02:09 PM   #6
SiNFuL
SiNFuL's Avatar
ok. if it works after i eliminate the switch, what should i do in order to keep it working w/ the switch?
-Galen
Old 09-09-2003, 02:13 PM   #7
DMC
DMC's Avatar
DMC is an unknown quantity at this point
hmmm....if you buy a new car and put the switch on it, it would work!
If it is someting electrcal try rplacing the button or checking all the wires and connections to the motor
DMC is offline   Reply With Quote
Old 09-09-2003, 04:37 PM   #8
SiNFuL
SiNFuL's Avatar
I think my wires just had a bad connection. I was fooling around w/ em and I think I'm good to go again! Thanks for all the tips!
-Galen
Old 09-09-2003, 05:45 PM   #9
kkw4p
kkw4p is an unknown quantity at this point
You probably had a grounding problem that you fixed when you messed around with it.
kkw4p is offline   Reply With Quote
Old 09-09-2003, 08:17 PM   #10
SiNFuL
SiNFuL's Avatar
i think it's hella loose though...Is there anyway I can make sure this grounding is perfectly stable(so it won't drop out when I hit a bump).
-Galen
Old 09-10-2003, 05:07 AM   #11
kkw4p
Find a good grounding point, drill and solder.
Old 09-12-2003, 10:51 PM   #12
SiNFuL
SiNFuL's Avatar
solder what?
-Galen
Old 09-13-2003, 10:21 PM   #13
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
don't need to solder, find a good factory ground and slip a crimp on connector below it. Simple, replaceable, easily removeable if you have to change something, and if you use a good klein crimper that uses a W crimp it will be stronger than solder.
andrave is offline   Reply With Quote
Old 09-14-2003, 09:33 PM   #14
SiNFuL
SiNFuL's Avatar
crimp what tho? One side of the green wire?
-Galen
