![]() Join Date: Dec 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
![]() Ok so I began writing my
"How to turbocharge a stock KA24DE with no mechanical experience" write up... Heres a link... 1/4 done. I wrote it all off the top of my head so I KNOW theres got to be some goofy bits that just plain arn't true, so if you spot one tell me. LINKAGE
Just a little thing, not really an error,
you have a table in phase 1 that shows 'the right turbo for the job'. You said a T25, T28 or small T3 is good for 175-210 on 5-6 psi. While not incorrect, its not really correct either. The T25 is fine, but the T28 and T3 dont really come into their efficentcy range until about 10-12psi. So you can actually run these turbos at higher boost to achieve more HP without having to go to a bigger turbo - especially if you go for a ball bearing version. But I certainly appreciate you being conservative in your figures, its a refreshing change from the 'a KA can do 500hp on stock internals' we see all the time. Top article! |
#4 | |
#5 | |
![]() Join Date: May 2003
I would NEVER put a T25 or T28 on a KA, but to be accurate:
With the T25, you're in the 60% range at 2500rpm With the T3, you're already in the 70% range by 2500. With the T25, you hang out in the 68% range and then the MAX of 70% until 4500...where the T3 is in the 74% range the whole time. By redline the T25 is at 60% again, and the T3 is hovering on the edge of the map at 65%. And that's at 6psi - The T25 SUCKS comapared to the T3, no matter the boost. So if we're shooting for "correct"...T25 and 28 suck for a KA, and T3 is pretty decent for anywhere from 4-14psi. Check out an overlayed (T25 and T3 - Both 60 trim) compressor map here: http://apps.freshalloy.com/albums/AsadMisc/abr.jpg Later - Brian |
#6 | |
As i'm getting the webspace I have currently as a favor...
#11 | |
![]() Join Date: Apr 2003
Im now the proud owner of a 1990 Maroon 5spd Hatch ![]() [Drift]: 1: to move or float smoothly and effortlessly...2: to move along a line of least resistance...3: gradual deviation from an original course... |
#13 | ||
First, the stock 270cc injectors will be maxed by ~195rwhp. (25.7*4*1)/.45 = 228 crank HP max, so lose 15%, and you get 194 - And thats at 100% duty cylce with a GENEROUS .45 BSFC for turbo) Secondly, a T25 is a bad match for a KA. Period. The exhaust housing is *tiny* for a 2.4, the compressor is quite inefficient, you may get surge under spool up - All the big things to consider point to NO. Please, don't think you can make it work - The numbers don't lie... I'm just trying to help you out, and doing the math to prove it. Please, save yourself the time and money and get a proper turbo. Don't even attempt it if you can't do it right... Later - Brian |
#14 | |
Autox Technician
![]() Join Date: Dec 2001
The thought process behind it: take an inefficient turbo, make up for it with a very efficient intercooler. Just to put it in perspective, some research says a TD05-12A (i have 12B housings) does 320 cfm max. A T25 does like 405 max.
#15 |
Nice website man, i look forward to see how your project is going to turn out
It is better to drive a Slow car fast than to drive a fast Car slow! '89 FastBack 5spd: Intake/Exhaust,Strut Bars and JL15. '90 Parts car/Some day drag car. |
#16 | |
2) Wow. I found a page that lists the TD05H-14B as flowing a 'practical' maximum of 385 CFM - On a KA, that's only ~5500rpm assuming 90% VE and 10psi. If yours is smaller...sh!t. That suckers spinning FAST...and spitting out some hot air. Anyway, I wouldn't reccomend such tiny turbos - Although they may work, for the same $$$ or less you hcan have a properly sized one, and a little room to grow. Later - Brian |
#17 |
you guys are kick ass.... im gonna have to do some more research then... ok.. so i dont want a t25.. im only wanting 200hp or so.. anything to get a lil more tq.. im no drag racer btw... thanks orion::S14 and AceInHole
btw nice page maeda.. i like the layout.. |
#18 |
Mayber as you go along you could include some prices and sources for some of the parts if you go time.
#20 | |
![]() Join Date: Jul 2001
#21 | |||
Autox Technician
yeah. turbine heats up air all it wants, and the IC brings temps back down. as long as a larger volume of air is being pushed, even if it's hotter, the IC will make up for it. haven't heat soaked the IC, ever, and am running 10psi (read at the intake plenum) currently. FWIW: my setup at 7.5psi was almost dead even with a T4 at 8psi. But, he was at a disadvantage running a JWT ECU... i've been wanting to try out a T3 just to see what it feels like. i've been trying to get a 14B to drop in for the longest time, since it'll swap into the turbine housing I have now, just replacing the oil lines and a V-band clamp. Quote:
One thing is: the scroll on my 12B is larger than the 14B's I've seen, and a LOT larger than the 12A I pulled the new center section from. I believe the A/R's on my turbo are better suited to the KA, which is why I might be getting away with it a bit better. It's not exactly easy trying to find A/R's on these though. Numbers are far more common for Garret turbos. My ideal turbo is either a GT30 or a GT28.... I'm still a long way from running one of those though. For now I'm either going to be running a 14B or a low A/R T3. I want to get the car up to 300hp after bumping fuel pressure and getting on a dyno. Quote:
#22 | |
2) Ahhhhhhh - Sounds like the reason. 385cfm is stupid, couldn't beleive it. And I ran into the same thing you have - Flow #s are elusive for 'mitsu' stuff!!! But if your A/Rs look bigger, who knows what the flow is...do you have pics of that thing? Post links...I have a few VERY knowledgable DSM friends - I'll ask them. 3) Mmmmmmmmm...GT30. On my wish-list as well... Later - Brian |
#23 |
Autox Technician
Some old shots of my 12B:
![]() vs. ![]() Notice how the scroll is much smaller than on my turbo. Mine actually sticks out from the center section plate (both plates are the same size), and has a bulkier scroll. Hopefully that means more flow, and a larger A/R. The the TD05-12B and a small T3 were both used on the same model/ year Volvo's, so I'm guessing they SHOULD be close.... The current centersection is from: TDO5-12A-8CM2 320 CFM I'm thinking a small trim T3 should be a good upgrade.
#24 |
Yeah...your's is quite comparable to a T3, with a tiny turbine...hehe.
I'd say go for the Z31 T3 - The firt KA-T I installed was a custom setup, JGS manifold, JWT + 370cc, and T3 - Bottom mount, and we utilized the OEM cast O2 housing for the turbo/downpipe connection - It's pretty slick... But like yours, it's always on. ANd unlike mine, when it boosts, you don't hear the WG - Just a beautiful "pppsssssssssss" and you're off. Driving that car made me build mine the next month... ![]() And the Z31's .63 A/R turbine housing should allow 300rwhp - A .48 housing, or that Saab turbo may not - They must choke it off. Later - Brian |
#25 |
has anyone ever used the mustang's SVO T3's before?
#26 | |
#27 |
Yah the project is done in case you havn't been following.
School is prolonging the write up process. Thanks for fielding my Q's Ace!
#28 | |||
Autox Technician
Can't wait to see the writeup too! Quote:
yeah. when i picked up the turbo it was next to a TD05-14B off an eclipse. I picked the Volvo unit thinking it had to be better since the scroll was so much bigger. Wasn't aware that a 12B meant a smaller compressor wheel though.... Quote:
now just imagine that car without the JWT ![]() As for power ratings from turbos... isn't that also dependent on head flow, cams, static compression, etc?? I'm hoping to take something like a small T3, and combine that with some small headwork and decent cams, maybe even a new intake manifold... in hopes of reaching 300rwhp.
#30 | |
So for 300rwhp, you'll need 30lbs/min. A T3 compressor can move that much air, but check the map - It'll take 10psi to make ~250rwhp from a T3 on a KA. So add another 5psi to get to 300rwhp (assuming no diminshing returns from things like small turbine housings) and you get 15psi (~2 pressure ratio) and 30lbs/min - And you're at the edge of the map, and at 65% efficiency. Seems do-able! And headwork/porting will hurt that auto-x friendly powerband - I'd do it with boost, not porting. I'd rather run a little bigger turbo compressor than a crazy top end intake mani or wild cams for auto-x... Later - Brian |
