Old 09-13-2003, 06:13 PM   #1
kickertu
kickertu is a well-known jackass
Injectors on sr not spraying... .any ideas???
So i have a redtop sr in my 90 hatch, and it has only ran right for about 4 hours, before something else went wrong... so i traced the problem to a bad injector. so i got new ones, and it started, but one of the lifters was making noise, so i pulled the valve cover, and checked.. found nothing wrong. so i put it back on and started plugging all the stuff back in, as well as plugging the injectors back in. when i plugged in the injectors the two wires crossed and they sparked. (the reason teh wires are exposed is because i bought blitz 550cc injectors and i started instaling them, and in order to do so, you have to cut the stock plugs off, and install new ones, and then i found out after they were wired that teh injectors dont fit. so i had to use just the wires as a temp fix) well now after that spark, the injectors wont spray.. at all...
So... I have replaced,
The ecu
The Engine Wiring harness
All the relays
checked all the fuses
hardwired my walbro fuel pump
and the injectors still wont spray.... i dont know what the deal is.. i have rotated the CAS to try timing, but no fuel is still comming...
if i pull the return line off the fuel rail, i do get fuel, and i am also getting spark..
anyone have any ideas???
kickertu is offline   Reply With Quote
