01-20-2011, 03:22 PM | #1 |
Chase Bays S13 SR20DET and S13 KA24DE Engine Harnesses Available Now!!
Finally complete!
Chase Bays S13 SR20DET Engine Harness Chase Bays S13 KA24DE Engine Harness A few things to note on the harnesses... SR20DET- We have integrated the upper and lower harnesses together to keep things clean and simple. The engine to chassis plugs are long enough to reach where they need to go whether you have stock fusebox location or relocated. We put the Coil Igniter plugs inside the car near the ECU/ECCS. This helps clean up the engine bay of course. MAF or MAP plug, we have a 3 pin deutsch connector coming out at the first junction. The reason we did this is since we all know there is plenty of MAF or MAP styles and locations we let you customize where it is and how it routes. The harness routes similar to the KA harness since they're just about the same thing, under the intake manifold. KA24DE- We have integrated the upper and lower harnesses together to keep things clean and simple. The engine to chassis plugs are long enough to reach where they need to go whether you have stock fusebox location or relocated. The harness routes underneath the intake manifold instead of over the top, significantly cleaning the motor up. For KA we would like to offer you the choice of S13 or S14 distributor/coil setup. Still working on that however. Pictures are kind of blurry, sorry. S14 motor and chassis harnesses coming ASAP. We also offer a RACE/Stand Alone style harness that has fuel, ignition, starter relays integrated and flying leads for you to connect yourself. Please ask any questions on this thread instead of PM so we can answer them and throw the Q&A on our website. Thanks for reading!
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE www.ChaseBays.com | [email protected] | (205)623-2188 Last edited by Chase Bays; 05-12-2011 at 04:04 PM.. |
