Old 01-20-2011, 09:04 PM   #1
2_Liter_Turbo
2_Liter_Turbo's Avatar
Trader Rating: (28)
2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough
Feedback Score: 28 reviews
Exclamation 2_Liter_Turbo's Epic Garage Sale - S13/S14/KA24DE/SR20DET/OEM/Aftermarket - Updated!
Welcome to my highly organized, and epically long, "for sale" thread. This is my entire stockpile of parts that I have in my garage that are up for sale! Most of this stuff is all OEM, but there are some aftermarket parts in the list. All prices are WITHOUT SHIPPING!!!!. Some prices are obo, some aren't. If there is an item that weighs 60 lbs and I'm only asking $10; don't offer $15 shipped for it. I will not ship a part and lose money for nothing. Use common sense when estimating an offer price shipped. The larger items I will get a quote for you, but due to the magnitude of this for sale thread, it may take me some time! If you do not see a part on this list that you are looking for, I DON'T HAVE IT! Also, when you are making an offer or asking for a shipping quote, include the part list number. If you do not, I will ignore your inquiry. This is a LONG LIST! If you do not wish to read through the list, you can look through the pics, and the list number is referenced next to each part. You can then look at the list and see how much I'm asking as well as a small description.
Well, enjoy:
001 Bare S13 SR20DET Intake Manifold $30.00
002 SR20DET Oil Pump Drive Collar $10.00
003 S13 SR20DET Main Bolts $10.00
004 S13 SR20DET Main Caps $10.00
005 S13 SR20DET Water Pump Pulley $15.00
006 S13 SR20DET T25 - Bad Bearings ***SOLD***
007 S13 SR20DET Alternator Bracket and Adjuster $30.00
008 S13 SR20DET Crank Pulley and Bolt $20.00
009 S13 SR20DET Power Steering Bracket $20.00
010 S13 SR20DET Turbo Manifold Heat Shield ***SOLD***
011 S13 SR20DET T25 Hard Lines $15.00
012 S13 SR20DET Turbo Manifold $30.00 ***SOLD***
013 S13 SR20DET Turbo Elbow - Not Modified $20.00 ***SOLD***
014 S13 SR20DET T25 Compressor Inlet ***SOLD***
015 S13 SR20DET T25 Actuator $15.00
016 S13 SR20DET T25 Compressor Outlet ***SOLD***
017 S13 SR/KA Engine Mount - Great Shape $15.00
018 3" Hole K&N Filter $15.00
019 S13 SR20DET (and KA) Clutch Fan (New Clutch) ***SOLD***
020 S13 SR20DET Oil Separator $10.00 ***SOLD***
021 S13 SR20DET Upper Oil Pan $25.00
022 S13 180SX Front Right Hub Assembly $20.00
023 Pair of 180SX Front Brake Line Brackets $10.00
024 S13 180SX Front Endlink (Slightly Bent) $5.00
025 S13 180SX Tension Rod $10.00
026 S13 180SX Charcoal Canister ***SOLD***
027 S13 180SX Charcoal Canister Bracket ***SOLD***
028 S13 180SX Right Front Lower Control Arm $15.00
029 S13 KA24DE/SR20DET Transmission Mount $10.00
030 S13 KA24DE Crank Pulley $15.00
031 S13 USDM Upper Chassis Cat Shield $10.00
032 Pair of S13 Rear Upper Control Arms $20.00
033 Pair of S13 Rear Toe Rods $20.00
034 Pair of S13 USDM Front Brake Rotors $15.00
035 Pair of S13 USDM Front Brake Calipers $30.00
036 Pair of S13 USDM Rear Brake Hoses $7.00
037 Pair of S13 USDM Front Brake Hoses $7.00
038 Pair of Z32 USDM Front Brake Hoses $7.00
039 Pair of S13 Front 4-Lug Hubs $20.00
040 Pair of S13 Battery Tie Downs $15.00
041 Q45 Igniter Chip with Pigtails $20.00
042 S13 Coupe Back Seat Pad $10.00
043 S13 USDM Center Console With Power Mirror $25.00
044 S13 USDM Ash Tray ***SOLD***
045 Pair of S13 Front Speaker Pods $15.00
046 S14 KA24DE Intake Inlet Tube $15.00
047 S13 USDM Lower Cat Shield $10.00
048 S14 KA24DE Intake Filter Box (No Filter) $20.00
049 S14 KA24DE Throttle Body Intake Coupler $15.00
050 R33 RB25DET Throttle Body w/ TPS $40.00 ***SOLD***
051 S13 USDM Sun Visors $15.00
052 S13 USDM Rear Sway Bar Endlink (Strait) $5.00
053 S13 USDM Rear Sway Bar Bushings & Brackets $7.00
054 S14 KA24DE Water Pump Pulley $15.00
055 S14 KA24DE Upper Radiator Hose $7.00
056 KA24DE Exhaust Manifold Heat Shield $10.00
057 S14 KA24DE EGR BPT Control Valve $15.00
058 S14 KA24DE EGR Valve $30.00
059 S14 KA24DE AICV $50.00
060 S14 KA24DE Air Valve $20.00
061 S14 KA24DE Intake Manifold $30.00
062 Was Told S13 Convertible Rear View Mirror $25.00
063 S14 KA24DE Fuel Pressure Regulator $20.00
064 S13 Rear Firewall Vibration Damper $5.00
065 S13 USDM Rear Seat Belt Latches $10.00
066 S13 USDM Coupe Rear Right Side Trunk Cover $10.00
067 S13 180SX Gas Pedal $10.00
068 Assorted (a-f) S13 Seat Mounting Covers $15.00
069 S14 OBDII 5 Speed Engine Harness (Cut) $40.00
070 S14 OBDII 5 Speed Misc Sub Harness $5.00
071 S14 USDM Cruise Control Cable $10.00
072 S13 KA24DE Water Pump Pulley $15.00
073 S13 SR20DET Intake Manifold $30.00
074 S13 SR20DET AICV $35.00
075 S14 KA24DE Intake Tube $20.00
076 S13/S14 KA24DE EGR Tube ***SOLD***
077 S14 USDM Cruise Control Bracket $5.00
078 S14 KA24DE Intake Box Parts $10.00
079 S13 Speed Sensor (Not sure what motor) Fits SR Trans $25.00
080 S14 KA24DE Radiator Support Brackets $10.00
081 S14 USDM Cruise Control Module $15.00
082 S13/S14 KA24DE Oil Cap $5.00
083 S14 KA24DE Shifter $15.00
084 S14 OBDII Misc Control Solenoids $15.00
085 S14 OBDII Evap Valve w/ Hoses $5.00
086 S13 5 Speed Shifter (Torn Boot) $17.00
087 S14 KA24DE Exhaust Manifold $15.00
088 S13/S14 KA24DE EGR Tube $10.00
089 S13 SR20DET Oil Pump Drive Collar $10.00
090 S13 SR20DET Pistons and Rods $40.00
091 S13 SR20DET Oil Dipstick and Tube $20.00
092 S13 USDM Front Sway Bar Bushings $5.00
093 S13 USDM Rear Sway Bar Bushings $5.00
094 S13 SR20DET Lower Oil Pan (Only Dent Shown) $20.00
095 S13 180SX Tension Rod $10.00
096 S13 SR20DET Valve Springs and Retainers $40.00
097 S14 KA24DE Air Valve $20.00
098 S14 KA24DE AICV $50.00
099 S14 KA24DE Intake Manifold $30.00
100 S14 KA24DE Intake Resonator Box $5.00
101 S14 KA24DE A/C Compressor $50.00
102 S14 KA24DE A/C Compressor Bracket w/ Adjuster $15.00
103 S14 KA24DE Fuel Rail $15.00
104 S14 KA24DE Fuel Pressure Regulator $20.00
105 S14 KA24DE Distributor w/ Wires ***SOLD***
106 S14 KA24DE Alternator $50.00
107 S13 KA24E 5 Speed ECU - CA Emissions $70.00
108 S13 KA24E 5 Speed ECU - Federal Emissions $70.00
109 S13 KA24DE Water Pump $15.00
110 S13 KA24DE Auto Speed Sensor $10.00
111 S13/S14 KA24DE Oil Cap $5.00
112 S13 KA24DE Valve Cover (White) $40.00
113 KA24DE Exhaust Manifold Heat Shield $10.00
114 S14 USDM Cruise Control Module $15.00
115 S13 USDM Automatic Brake Pedal $10.00
116 S13 USDM Automatic Shifter $15.00
117 S13 USDM Automatic Shifter Trim $5.00
118 S13 KA24DE Power Steering Pump Bracket $10.00
119 KA24DE Intake Manifold Bracket $5.00
120 KA24DE Upper Timing Chain (Great Shape) $10.00
121 KA24DE Intake Manifold Bracket $5.00
122 S13 SR20DET Boost Solenoid Setup $5.00
123 S13 Air Intake Temp Sensor $10.00
124 Misc Nissan Resistor Box (S14 Auto Tranny?) $5.00
125 KA24DE Head Bolts $10.00
126 S13 HICAS PS Fluid Reservoir $20.00
127 S13 USDM Rear Seat Belt Latches $10.00
128 S13 B-Pillar Exterior Trim Pieces $15.00
129 S13 KA24E PS Fluid Reservoir $10.00
130 Q45 Igniter Chip with Pigtails $20.00
131 S13 Rear Red Side Marker $5.00
132 S13 Right Side Manual Mirror Housing $10.00
133 S13 USDM Lap Belts $15.00
134 S13 Rear Strut Caps $10.00
135 S13 Radiator Bracket $5.00
136 S13 Manual Mirror Covers (Some broken tabs) $5.00
137 Home Made 240SX Test Pipe ***SOLD***
138 S13 180SX (RHD) Under Dash Trim Piece $20.00
139 S13 180SX (RHD) Glove Box Support Bracket $10.00
140 S13 180SX (RHD) Under Dash Wiring Harness ***SOLD***
141 S13 KA24DE MAF (Works on S13 SR20DET Swaps) $50.00
142 S13 KA24DE MAF (Works on S13 SR20DET Swaps) $50.00
143 S14 SR20DET MAF (Part #: 22680 53F00_A36-000 G60) $50.00
144 S13 SR20DET Alternator Pulley $10.00
145 S13 USDM Trunk Cover Holder $10.00
146 S13 Speed Sensor (Not sure what motor) Fits SR Trans $25.00
147 S13 KA/SR Exhaust Side Engine Mount $15.00
148 KA24DE Intake Box Plastic Coupler $5.00
149 KA24DE Alternator Adj Bracket $15.00
150 S13 KA24DE Power Steering Pump (Can use for SR) $50.00
151 S13 KA24DE EGR BPT Control Valve $10.00
152 S13 KA/SR Intake Side Engine Mount $15.00
153 S13 KA24DE A/C Compressor Bracket w/ Adjuster $15.00
154 S13 Drive Shaft Carrier Bearing Bracket $5.00
155 S13 KA24DE Center Timing Chain Sprocket/Bolt $20.00
156 S13 5 Speed Tranny Clutch Fork $10.00
157 S13 Exhaust Mount ***SOLD***
158 S13 SR 5 Speed Tranny Rear Dust Cover $5.00
159 240SX Exhaust Side Emissions Bracket $5.00
160 KA24DE Power Steering Pump Pulley $15.00
161 S13 Exhaust Mount Hanger $10.00
162 S13 Exhaust Mount $10.00
163 S13 SR20DET Coolant Temp Sensor Housing $20.00
164 SR20DET Power Steering Pump Pulley $15.00
165 240SX 5 Speed Throw Out Bearing and Carrier $15.00
166 S13 SR20DET Rear Main Seal Housing $15.00
167 S13 SR20DET OEM Fuel Rail $30.00
168 S13 SR20DET Oil Pickup Baffle $20.00
169 S13 SR20DET Oil Pickup $15.00 ***SOLD***
170 S13 KA24DE EGR Valve $25.00
171 S13 240SX Trunk Emergency Jack $20.00
172 S14 SR20DET Oil Pickup $25.00 ***SOLD***
173 S13 SR20DET OEM Flywheel $30.00 ***SOLD***
174 240SX KA24DE Water Outlet $15.00
175 S14 USDM Cruise Control Cable $10.00
176 240SX Battery Tie Down $7.50
177 240SX Battery Tie Down ***SOLD***
178 S13 240SX Brake Master Cylinder Reservoir $10.00
179 S13 Exhaust Mount Hanger $10.00
180 S13 SR20DET Alternator Bracket and Adjuster $25.00
181 S13 SR20DET Intake Cam Sprocket $15.00
182 S13 SR20DET Exhaust Cam Sprocket $15.00
183 S13 KA24DE Crank Pulley $15.00
184 S13 SR20DET Oil Filter Block $15.00
185 S13 SR20DET Alternator Bracket Lower Brace $5.00
186 S14 KA24DE Exhaust Manifold $15.00
187 S13 SR20DET Turbo Manifold $30.00 ***SOLD***
188 S13 KA24DE Starter $50.00
189 S13 KA24DE Alternator $50.00
190 S13 SR20DET Turbo Elbow - Modified $25.00 ***SOLD***
191 S14 KA24DE Auto ECU (C6: A18-E28 G77) $70.00
192 Pair of S13 Front Speaker Pods $15.00
193 S13 Dash Center Vents (Trim Painted White) $10.00
194 S13 180SX (RHD) Gas Pedal Stop $15.00
195 S13 Seat Back Support Spring (front seat) $5.00
196 S13 KA24DE Intake Box Inlet Tube $15.00
197 S13 USDM Right Side Shoulder Belt $15.00
198 S13 USDM Rear View Mirror $20.00
199 S13 USDM Power Seat Belt ECU $15.00
200 S13 180SX (RHD) Center Inside Dash Vent Coupler $15.00
201 S13 180SX (RHD) Lower Steering Column Trim ***SOLD***
202 S13 180SX (RHD) Upper Steering Column Trim ***SOLD***
203 S13 180SX (RHD) Center Inside Dash Vent Piece $25.00
204 S13 USDM A-Pillar Mounting Bracket $5.00
205 S13 USDM Steering Wheel $20.00
206 Assorted (a-f) S13 Seat Mounting Covers $15.00
207 S13 USDM Pair of A-Pillar Mounting Brackets $10.00
208 S13 180SX (RHD) Dead Pedal ***SOLD***
209 S13 180SX (RHD) Gauge Surround Buttons (a-c) $45.00
210 S13 Manual Engine Bay Fuse Box Cover ***SOLD***
211 S14 MAF (Flange Cut For Cone Filter) $40.00
212 S13 Unknown Interior Bracket $5.00
213 S13 Pop-Up Headlight Harness $5.00
214 S13 180SX (RHD) Dual Bumper Blinker Harness $15.00
215 S13 180SX (RHD) Horn $20.00
216 S13 Pop-Up Headlight Harness Cups $5.00
217 S14 USDM Automatic Brake Pedal $10.00
218 S13 USDM Pop-Up Headlight Bucket $10.00
219 S13 USDM Plastic Battery Tray $10.00
220 S13 240SX Driver Side Lower Bumper Vent $10.00
221 S13 USDM Windshield Squirter Motor and Reservoir $35.00
222 S13 240SX Gas Pedal $10.00
223 S13 240SX Charcoal Canister $10.00
224 S13 240SX Exhaust Side Recirc Valve (Emissions) $40.00
225 S13 USDM A-Pillar Mounting Bracket $5.00
226 S13 USDM Bumper Mounting Brackets $15.00
227 KA24DE Exhaust Manifold Heat Shield $10.00
228 S13 USDM Lower Cat Shield $10.00
229 S13 USDM Passenger Side Headlight Cover $15.00
230 S13 USDM Passenger Side Headlight Cover $15.00
231 S13 180SX (RHD) Steering Column ***SOLD***
232 S13 180SX (RHD) Radiator Bracket (I think) $10.00
233 S13 180SX (RHD) Emissions Pipe (Bolts to Rear of SR Head) $10.00
234 S13 180SX (RHD) SR Emissions Bracket $5.00
235 S13 180SX (RHD) SR Emissions Solenoid $5.00
236 S13 SR20DET T25 - Shaft Play ***SOLD***
237 S13 SR20DET T25 Hard Line $5.00
238 S13 180SX (RHD) SR Emissions Solenoid $5.00
239 S13 180SX (RHD) SR Emissions Device $10.00
240 S13 Speed Sensor (Not sure what motor) Fits SR Trans $25.00
241 S13 SR20DET Intake Manifold Bracket $5.00
242 240SX Battery Tie Down $7.50
243 S13 SR20DET Water Pump (Lower Miles) $20.00
244 S13 SR20DET Turbo Manifold $30.00 ***SOLD***
245 S13 SR20DET Turbo Manifold Heat Shield $20.00 ***SOLD***
246 S13 KA24DE MAF (Works on S13 SR20DET Swaps) $50.00
247 S13 180SX HICAS PS Fluid Reservoir $20.00
248 S13 180SX (RHD) Brake Pedal $10.00
249 GTIR SR20DET Individual Throttle Body Manifold Setup ***SOLD***
250 S13 SR20DET OEM Injector $40.00
251 S13 SR20DET OEM Injector $40.00
252 S13 SR20DET OEM Injector $25.00
253 S13 KA24DE OEM Injector ***SOLD***
254 S13 SR20DET OEM Injector $14.00
255 S13 SR20DET OEM Injector $17.00
256 S13 SR20DET OEM Injector $20.00
257 S13 KA24DE OEM Injector ***SOLD***
258 S13 LHD Black Dash (Good Condition) - Small Flaws Pictured ***SOLD***
259 S13 LHD Black Door Panels (Passenger Side Flaw Pictured) ***SOLD***
260 Used Circuit Sports Oil Catch Can ***SOLD***
261 Fake Ebay Greddy Blow Off Valve with Pipe/Flange $40.00
262 Electric Fan $15.00
263 B13 SE-R Sentra Momo Steering Hub (Not sure if it fits S13) $45.00
264 Momo Steering Wheel Horn Button $15.00
265 S13 Silvia Ks Front Bumper/Foam/Bumper Support $240.00
266 S14 KA24DE Auto Tranny Radiator $50.00
267 S14 KA24DE Radiator Shroud $25.00
268 S14 KA24DE A/C Condenser Fan $15.00
269 S13 240SX Convertible Rear Sway Bar $15.00
270 S13 180SX (RHD) HICAS Steering Rack and Subframe $150.00
271 S13 KA24DE Radiator Shroud $20.00
272 S13 A/C Condenser $20.00
273 S13 180SX Front Sway Bar $25.00
274 S14 KA24DE Auto Tranny Radiator $40.00
275 S14 KA24DE Radiator Shroud $25.00
276 S14 KA24DE A/C Condenser Fan $15.00
277 S14 KA24DE Lower Radiator Hose $10.00
278 S13 Redtop SR20DET Assembled Cylinder Head $140.00 ***SOLD***
279 S13 HKS 3" JASMA Catback with Resonator Cut Out ***SOLD***
96 S14: Grip Track Car
90 R32: Bucket List Car
92 S13: Just for Fun Car
Instagram: @SS.Maxey
2_Liter_Turbo is offline   Reply With Quote
Old 01-20-2011, 09:05 PM   #2
2_Liter_Turbo
Trader Rating: (28)
Hopefully this doesn't count as my first bump, lol. I had more than 50 images, so I HAD to have two posts!
Old 01-20-2011, 09:07 PM   #3
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
holy hell that is a huge for sale thread that is greatly organized. glws.
SW Fab
shiftdrift is offline   Reply With Quote
Old 01-20-2011, 09:33 PM   #4
Pure_JDM
Pure_JDM is an unknown quantity at this point
First off, hands down the best for sale thread ever (at least from an organizational standpoint).
Secondly, it's not mentioned, and yes I did read your bold print... but it's still worth asking, do you have the little sub harness that connects from the Coolant Temp Sensor and Thermal Transmitter to the main engine harness on an SR20DET?
Pure_JDM is offline   Reply With Quote
Old 01-20-2011, 09:36 PM   #5
SiDwAyZ240
SiDwAyZ240 is an unknown quantity at this point
Didn't see any listed but with all these parts I gotta ask: got any S13 KADE exhaust cams (248)?
SiDwAyZ240 is offline   Reply With Quote
Old 01-20-2011, 09:39 PM   #6
startupdc5
startupdc5 is an unknown quantity at this point
how much for item 105 s14 distributor shipped?
startupdc5 is offline   Reply With Quote
Old 01-20-2011, 10:05 PM   #7
2_Liter_Turbo
Trader Rating: (28)
Thanks!
Thanks!
I do not, sorry.
I do not, sorry.
$62 Shipped. PM me for paypal info, thanks!
Old 01-20-2011, 11:40 PM   #8
charles13
charles13 is an unknown quantity at this point
dohc cluster?
charles13 is offline   Reply With Quote
Old 01-20-2011, 11:46 PM   #9
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
where can I pick up the exhaust from ?
Old 01-20-2011, 11:50 PM   #10
2_Liter_Turbo
Trader Rating: (28)
Originally Posted by charles13 View Post
dohc cluster?
I do not, Sorry.
Salem, OR.
Old 01-21-2011, 12:07 AM   #11
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
very well done fs thread
spooled240 is offline   Reply With Quote
Old 01-21-2011, 02:48 AM   #12
SharkMan
SharkMan's Avatar
Trader Rating: (28)
SharkMan is an unknown quantity at this point
Holy Sh*t, bump for someone who means business on their fs thread. Have any blinker/bumper blinker male pigtails? Glws man.
Front hugs or from behind hugs?
Originally Posted by nissan240 View Post
The Black Star Ninja is my real father...
SharkMan is offline   Reply With Quote
Old 01-21-2011, 08:22 AM   #13
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
How much for #278 shipped to 29904? Thank you!
Driftphreak87
Okinawandrifter87 is offline   Reply With Quote
Old 01-21-2011, 08:25 AM   #14
2fast4y0u
2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore
ill take the catch can #260. hows $25 shipped sound? thats $10 for shipping
2fast4y0u is offline   Reply With Quote
Old 01-21-2011, 11:07 AM   #15
G35_S13_Coupe
G35_S13_Coupe's Avatar
G35_S13_Coupe is an unknown quantity at this point
I want items 14 and 16. 5155594256 and we can work something out.
Thanks
G35_S13_Coupe is offline   Reply With Quote
Old 01-21-2011, 08:03 PM   #16
Razi
Razi is an unknown quantity at this point
Can you do $20 shipped on the SR manifold heatshield (#010) to 92881?
PM me!
Razi is offline   Reply With Quote
Old 01-22-2011, 09:06 AM   #17
BoostinEuros
BoostinEuros is an unknown quantity at this point
Bump for great parts! I'd get that exhaust if you weren't on the other side of the continent!
BoostinEuros is offline   Reply With Quote
Old 01-22-2011, 10:50 AM   #18
blink182house
blink182house's Avatar
blink182house is on a distinguished road
Send a message via AIM to blink182house
free bump for an extremely organized for sale thread, and for someone who obviously put in a lot of extra time to do it right. props! glws!
-Scott :: TRACTIONOPTIONAL.com
blink182house is offline   Reply With Quote
Old 01-22-2011, 12:35 PM   #19
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
BEST....FOR SALE...THREAD.....EVAR!!!
needs to be stickied lol
free bump
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 01-22-2011, 04:51 PM   #20
Z28ricer
Z28ricer is an unknown quantity at this point
Please PM me shipping cost on the following all together:
006 T25 bad bearings (provided the exhaust wheel hasnt hit the housing and been damaged
140 RHD dash harness
231 RHD Column
Z28ricer is offline   Reply With Quote
Old 01-23-2011, 11:55 AM   #21
Hollywood30
Hollywood30 is an unknown quantity at this point
Would you happen to have a clutch pedal assembly for s13 or s14?
Hollywood30 is offline   Reply With Quote
Old 01-23-2011, 12:07 PM   #22
Paper_Tiger240
Paper_Tiger240's Avatar
Paper_Tiger240 is an unknown quantity at this point
bump for clean and well organized thread
Paper_Tiger240 is offline   Reply With Quote
Old 01-23-2011, 11:27 PM   #23
Z28ricer
Realized my PM box was full, if you tried to send me that shipping cost, please resend.
Old 01-24-2011, 02:34 AM   #24
miravete
miravete's Avatar
Trader Rating: (44)
miravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant future
Feedback Score: 44 reviews
very well organized for sale thread...only if all were like this lol
price shipped on number 76 (s14 egr tube)
shipped to 92120
taking corners just as good as a drunken rhino..
miravete is offline   Reply With Quote
Old 01-24-2011, 05:46 PM   #25
john891
john891 is an unknown quantity at this point
price on 039 (s13 front hubs)
shipped to 23221
thanks!
Image exceeds forum limits of 400wide x 200 high.
gold 89' SR'd coupe w/ silvia front
john891 is offline   Reply With Quote
Old 01-24-2011, 06:15 PM   #26
Prez
Prez's Avatar
Prez is an unknown quantity at this point
WELL DONE!...GLWS still browsing... theres alot
"soft so you can't even enjoy it"
Prez is offline   Reply With Quote
Old 01-24-2011, 06:39 PM   #27
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
props, i love your thread. its a bit overwhelming but the organization is incredible.
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 01-24-2011, 09:01 PM   #28
miravete
miravete's Avatar
Trader Rating: (44)
payment sent on one of the s14 egr tubes
Old 01-25-2011, 10:23 AM   #29
Kirin240
Kirin240 is an unknown quantity at this point
Send a message via AIM to Kirin240
Can you PM me for price shipped for:
253 S13 KA24DE OEM Injector $25.00
257 S13 KA24DE OEM Injector $25.00
to 07083?
thanks!
Kirin240 is offline   Reply With Quote
Old 01-25-2011, 12:25 PM   #30
Drftr915
Drftr915's Avatar
Trader Rating: (22)
Drftr915 is an unknown quantity at this point
Bump for taking the time to make a really good for sale thread.
Drftr915 is offline   Reply With Quote
