Old 01-22-2011, 09:31 AM   #1
Edwin562
Edwin562's Avatar
KA loss of battery power after clutch job/starter
i recently noticed that everytime i work around the starter, some how battery completly drains.. i recently just picked up another hatch.. dual cam, and i was doing a clutch job... everything went it smoothly but once i connected the negative cable to start her up, i here a small eletrical crack... didnt really paid attention to it but once i cranked, it will turn over but not start like if my battery is dead... battery is 2 months old.. im leaning over that i have a short somewhere at the starter.. also have the same problem with my black hatch SOHC.. new battery but not turn on with battery alone... anyone have a solution to this problem???
Old 01-22-2011, 09:34 AM   #2
Edwin562
Edwin562's Avatar
yet before i did the clutch job, engine turned on normally... it just started doing this after i did the clutch job...
Old 01-22-2011, 09:40 AM   #3
chigga311
chigga311 is an unknown quantity at this point
Check your grounds!!!!
Also make sure you didn't switch the power and ground wires on the starter.
chigga311 is offline   Reply With Quote
