Old 01-26-2011, 11:42 PM   #1
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
for all you alarm junkies
alright so i attempted to install my alarm today its a viper 5901 with remote start..
i used this website right here
1989-90 Nissan 240 SX Alarm, Remote Starter, Keyless Entry Wiring Information
heres the first 12 pin main connector
a couple things i don't get... the input and output confuse me..
first off, the red/white aux trunk output, goes to the red wire (light in trunk) right?
(white/brown) parking light isolation, does that go to parking light (red/blue) wire in my light switch? there is also another "parking light output" (white) wire does that go to the (red/blue) wire on my light switch also?
im assuming ORANGE and BLACK both just get grounded?
and as for "trunk pin instant trigger" is that this thing? if so i just run the blue wire to it right?
Options13 is offline   Reply With Quote
Old 01-27-2011, 12:04 AM   #2
hpipro4
hpipro4's Avatar
Trader Rating: (71)
hpipro4 is an unknown quantity at this point
Feedback Score: 71 reviews
just did this on my s13 few weeks ago so im assuming your installing this on s13 too? if so the only wires you need is as follow...
h1/1 not used unless you have trunk popper
h1/2 connect to live power frm battery+
h1/3 to siren red wire
h1/4 not use
h1/5 chassis ground
h1/6 not use
h1/7 red wire on the trunk switch
h1/8 red/white behind driverside kick panel(or any door switches)
h1/9 optional
h1/10 optional
h1/11 red/blue behind driver kick panel
h1/12 not use
that pic is the hood switch as s13 doesnt have em...u can place it anywer u like under the hood just make sure it get pushed when hood is close.
hpipro4 is offline   Reply With Quote
Old 01-27-2011, 12:11 AM   #3
Options13
Options13's Avatar
Trader Rating: (43)
oh perfect! for h1/7 is the red wire actually in the trunk? oh and also there is another 18 pin connector, im assuming this isn't used at all? this part really confused the shit out of me...lol
Old 01-27-2011, 12:42 AM   #4
hpipro4
hpipro4's Avatar
Trader Rating: (71)
[QUOTE=Options13;3850388]oh perfect! for h1/7 is the red wire actually in the trunk? oh and also there is another 18 pin connector, im assuming this isn't used at all? this part really confused the shit out of me...lol
ull find it behind driver kick panel too but mine is directly frm the switch bc i took out the lite on the back aka rewired the interior wiring.
ull need some of those wires frm 18pin if ur planning on remote starting which ill get bak to u tmr nite..
Old 01-27-2011, 12:54 AM   #5
Options13
Options13's Avatar
Trader Rating: (43)
ahh ok yeah im just trying to get the alarm just set up for now! i'll setup the remote starter once its warmer outside, lol
yeah man get back to me! thanks so much
Old 01-27-2011, 12:58 AM   #6
xpertsnowcarver
xpertsnowcarver's Avatar
Trader Rating: (44)
xpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud of
Feedback Score: 44 reviews
What a coincidence. I just bought this alarm system two days ago and was thinking of doing a How-To for it. Thanks for the link.
My YouTube Channel
xpertsnowcarver is offline   Reply With Quote
Old 01-27-2011, 01:01 AM   #7
Options13
Options13's Avatar
Trader Rating: (43)
hell yeah, if you do a how too that would be great!
the lcd remote is cool, i like how you can change the colors of the screen, lol
Old 01-27-2011, 01:20 AM   #8
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
hpipro4 is a freak when it comes to this lol
anyways somebody should do a write up on this. (including how to put a trunk popper)
i've always wanted an alarm for my car but i didnt wana pay for installation and all that...
@ xpertsnowcarver do it man! make a write up on how to install this.
REVIEW
killer240 is offline   Reply With Quote
Old 02-17-2011, 12:11 AM   #9
xpertsnowcarver
Trader Rating: (44)
Well.. I never got around to doing a write up. I was pressed for time, and I just wanted to get this over with.
I just finished right now, so I'd like to post a few things now before I forget.
This is specifically refering to the Python 991 (or Viper 5702P or whatever the matching model is..) on my 91 S13.
I didn't bother setting up remote start, but I left it there ready for when I stop being lazy.
The H3 (Remote Start) Harness is necessary however, even if you don't care to use remote start. There is only one wire you need to use and that is H3/1 (Pin 1) Pink. This wire needs to tap into the Ignition wire (Black/Red - Harness connector CAR SIDE). This is needed so the alarm can see that you acknowledge any disturbances it has reported to you. Once you put the key in the On position, it will reset the notifications.
Also, the Purple and Green wire from the H3 harness are not needed, but I recommend them. The alarm could be used as a kill switch. You would cut the starter wire going to the starter solenoid. (PLEASE REFER TO THE FSM TO DETERMINE THIS WIRE). The green and purple wires go to the cut starter wire.
So if one were to force entry and attempt to start the car, it should not start because you still have not disactivated the alarm.
(AT LEAST THAT IS WHAT I UNDERSTOOD.... I attempted this, but I was still able to start my car... So, I need to figure out where I went wrong.. I'm just throwing my notes out there for you guys to figure out on your own.)
I pretty much did the same exact thing as above for everything else.
Note. When you see (-), this means tap into the ground wire side. When you see (+), it mean tap into the power wire side.
Here is a link for wiring door lock actuators. http://www.commandocaralarms.com/dow...kactuators.pdf
My YouTube Channel
Old 03-14-2011, 01:02 AM   #10
Options13
Options13's Avatar
Trader Rating: (43)
alright, so i'm having a few problems with my alarm, when i go to lock the car, aren't my lights supposed to flash or something? and also it will say i have a door open when i don't lol
AND when i unlock the car, the blue viper light will still blink, blinks 2 times then stops, then blinks 2 times again, know the reason for this?
Old 03-14-2011, 01:52 AM   #11
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
check your h1/11 wire- for parking lights +
Check your h1/8 Wire- DOOR TRIGGER-(-) 240sx is a - trigger make sure u did not wire in the + trigger (h1/6)
built ka-t
importdude is offline   Reply With Quote
Old 04-17-2017, 11:16 PM   #12
Eoken
Eoken is an unknown quantity at this point
thank you!! I did not connect my pink wire and my system would not clear my alarm trigger code XD
Eoken is offline   Reply With Quote
