Old 01-30-2011, 08:16 PM   #1
nissan240sxkid
nissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enough
Exclamation ‘92 Nissan 240sx Coupe S13 Silvia & TONS of PARTS FOR SALE!!
Make/Model/Trim: Nissan 240sx Coupe
Year: 1992
VIN: JN1M34P0NW106234
Mileage: 180000 (Chassis Only)
Engine Type: S13 SR20DET Blacktop
Transmission Type: 5-Speed Manual
Options: Power locks, Power windows, Power steering, Power Sun-Roof
Modifications: See Lists Below
Any Included Parts, if applicable: See Lists Below
Flaws (mechanical and otherwise stated in order of importance): See Description Below
*** ‘92 Nissan 240sx Coupe S13 Silvia & TONS of PARTS FOR SALE ***
I was driving when someone decided to change lanes into me and damaged the front passenger fender, hood, passenger headlight, tie rod, and now both drivers side rims have curb rash. The car still runs great and will drive perfect once the tie rod is replaced. There’s no frame damage, as you can see from the photos. I understand that all I need is a few hundred bucks to fix it and it would be fine, but the truth is, I was thinking about selling the car before this accident. I have had this car for about 5 years and have been slowly building it as a side project, but I’ve gotten multiple tickets and now with the accident I’ve just lost interest in it all together.
Most of these parts are barely used with less than 3000 miles on them, since this car was only occasionally driven and had sat for about 3 years in storage with no motor. The car currently makes 420rwhp on pump gas at low boost (19-20psi). If you want to run race gas and turn up the boost, all of the parts and the fuel system are in the car and able to handle more power. The car is very fast and with a more appropriate drag radial on the car it will suit the drag strip well, but it still spools fast enough to drift. It handles very well on the street and the HKS Hi-power exhaust is surprisingly quiet.
I’m not an amateur car enthusiast and I know my way around the 240sx. I’m a professional mechanic, and although it may not look like a showroom car as it sits now, it is mechanically sound. I was working on getting it painted and putting all of my finishing touches on it, including lap belts, and a radio. I have a lot of spare parts and miscellaneous items to sell, including other engines, transmissions, etc. I’d like to sell everything that I have that is Nissan and 240sx related, including the car as a whole running vehicle.
The following list is for the car as a whole running car with all of the parts it includes, and another list is for all of the other miscellaneous parts that I would like to also sell. If someone would like to make me an offer to take everything, I would consider it. If the car doesn’t sell, I will end up parting it out. I might have invested over $40,000 between chassis’s, motors, parts that I’ve had and sold in the past, etc. I understand I won’t get anywhere near that back, but the car and all of the parts are still worth good money.
I haven’t yet listed any prices on the parts or the car, so please don’t low-ball, but I would like reasonable offers.
PM me or email me and send payments to my PayPal at [email protected]
Shipping parts and/or the whole car will be the responsibility of the buyer, however I am willing to cooperate and I can fix the tie rod for the right buyer.
Pictures will be posted up shortly... Thank you for your patience
1992 Nissan 240sx Coupe S13 Silvia includes the following:
ENGINE & DRIVETRAIN
SR20DET Blacktop
Wiseco Pistons
ACL Bearings
ARP Head studs
HKS Head gasket
GReddy Pulley Kit
ATi Engine Dampener
ATS Triple Carbon Clutch
Custom Twin Scroll T4 Manifold
GT3582R w/ Twin Scroll back housing
(2) TiAL 44mm Wastegates
Custom Dump tubes & Downpipe
ALL Turbo lines are Stainless Steel Braided & have AN fittings
Turbo blanket
4” Intake w/ AEM Filter
“Mr. Gasket” Exhaust Manifold Gasket
HKS Hi-Power CAT-back Exhaust
GReddy Intake Manifold
70mm Pulsar Throttle body (water fittings and other idle things machined off)
SARD Fuel Rail
Precision 1000cc Injectors
SARD Fuel Pressure Regulator
Aeromotive Fuel Filter
-8AN Stainless Steel Braided Fuel Feed line & fittings
-6AN Stainless Steel Braided Fuel Return line & fittings
BOSCH 044 Fuel Pump (externally mounted w/ bulkhead under fuel tank)
GReddy Oil Cooler (mounted but never plumbed up or used)
Nismo Motor mounts & Tranny mount
Splitfire Coil Packs
TiAL Purple 50mm Blow-off Valve
GReddy Type-R Intercooler (piping modified to fit)
GReddy Upper Intercooler pipe (modified for TiAL BOV)
Power Enterprise Belts
Wire tuck w/ rear mounted battery & no fuse boxes in engine bay (only 90% complete – everything works but final tuck in cabin needs to be done)
Samco hoses – Upper and lower (Black)
Koyo Radiator
Flex-a-lite Fans (controlled by ECU)
HKS F-con V-Pro 3.4 (Newest version)
B&M Short Shifter
“Drive Shaft Shop” Aluminum 1 piece Drive Shaft
Nismo Slave Cylinder
Agency Power Stainless Steel Braided Clutch line
New Master Cylinders for Brakes and Clutch
Nismo Pro 2-Way Rear Differential
Brake Master Cylinder Heat Shield
Blitz Radiator Cap
JAZ Radiator Overflow Bottle
Hallman Manual Boost Controller
CHASSIS & SUSPENSION
S13 Silvia Front End (or what’s left of it)
HID Headlights
Tanabe Sustec Pro-DD Coilovers
Upgraded Tension Rods
TEIN Inner & Outer Tie Rods
Battle Version Control Arms
JIC Toe Arms
Kazama Control Links
Brembo Rear Rotors
Wilwood Front Upgraded Big Brake Kit (Slotted 2-pc Rotors)
Peak Performance 5-Lug Front & Rear Hubs (Front has their nicer kit with extended studs, made of Chromoly)
5-Zigen 17” Rims (Fronts: 17x9+15, Rears: 17x10+12)
Cooper Tires (Plenty of life left)
Wangan Rear Spoiler (stock spoiler too)
Rolled Rear Quarters
INTERIOR
Key!s Suede Steering Wheel
Momo Wheel Hub
Sparco Quick Release (w/ a machined adapter plate to work together)
Yashio Factory Shift Knob & Shift Boot
BRIDE Upholstered Rear Seat
BRIDE Upholstered Glove Box
Stock 240sx Leather Front Seats
Brand New Black Carpet (not installed)
Omori 60mm Boost Gauge
AEM 52mm Wideband
Heads-up Display Speedometer
ALL OTHER NISSAN & 240sx RELATED PARTS (not included with the car):
ENGINES & DRIVETRAINS
S13 SR20DET Redtop Head
S13 SR20DET Blacktop Head
Built S13 SR20DET Blacktop Head (worked on by Head Games & Mazworx w/ machined quench areas, Manley 1mm over stainless steel valves, Tomei solid lifters, Tomei Rocker Arm Stoppers, Tomei Cam Gears, SuperTech Dual Valve Springs, Titanium Retainers, drilled out for ½” Head studs)
S13 SR20DET Blacktop Block (w/ Darton Sleeves pressed in & machined to 87mm, CP Pistons 87mm-Brand New in Box, Manley TurboTuff Rods, ARP ½” Head Studs, ARP Main studs, New Water pump, New Oil pump, New Timing chain & New guides, New Gaskets)
Kelford 274/278 Int./Exh. Cams (Brand New in Box)
S13 SR20DET Valve cover, Shaved, -10AN fittings for breathers
Yashio Factory Water Pump Pulley (Brand New in Box)
GReddy Chrome Oil Cap
OSGiken 3-speed Set – New in Box
OSGiken Input Shaft
S14 Manual 5-speed Transmission
S13 SR20DET 2.0L Crank
ARC Gradient Plug Cover for S13 SR20DET
S13 SR20DET Transmission (disassembled)
INTERIOR & EXTERIOR
S13 240sx Dash
JDM Gauge Cluster w/ 9000rpm Tachometer
Key!s Suede Shift Knob (matches Key!s wheel in car)
Exterior Parking Lights
MISCELLANEOUS
S13 SR20DET Stock Intake Manifolds (4 or 5 available)
Stock S13 Driveshaft
Battle Version (or replica) Front Lower Control Arms for S13
DIF Dual Fan Controller
Yashio Factory Radiator Cooling Panel
A few Starters
A few Alternators
Several Brackets
Loads of Nuts & Bolts
Plugs, Wiring, Etc.
Z32 MAF Pigtail
S13 A/C Condenser
KA24DE A/C Compressor
SR20DET A/C Compressor
Stock Flywheel
Bell Housing Plates
Fuse Box Covers
GReddy E-Manage Ultimate Harness
Stock Glove Box
Stock Suspension Arms
Goodridge Rear Stainless Steel Braided Brake Lines – New in Box
Pair of 5-Bolt Axles
Brass Bushings for Door Hinges – New in Box
Shift Boot Ring
Stock Shift Knob
Stock Shift Boot
Megan Sub-frame Bushings – Never installed
GReddy Downpipe (cut in half but I can TIG it back together)
nissan240sxkid is offline   Reply With Quote
greddy, hks, s13, s14, silvia
