S13 KA Transmission Whine
Today on the way to school my S13 (KA) started making a whining noise from the transmission area. It wasn't that loud, but it was more apparent on the way back. When accelerating in 1st, 2nd, and 3rd gear it makes an loud whining noise, but it is fine in 4th; which from researching I understand is because of the 1:1 ratio in 4th. When the push the clutch pedal down the noise goes away, be it in neutral or in gear. When in neutral it there is a chattering noise, not loud, but there.
The tranny has about 155,000 on it and when I got the motor from the last owner it had 140,000. From what I've read, could it be the throwout bearing? I was thinking of changing the clutch, but I wanted to make sure that it wasn't something else before I do. |
#6 |
![]() Join Date: Nov 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
Make sure you replace everything if you can afford to.
-Rear main seal on the block -Pilot bushing -Throwout bearing -Clutch disk (clutch cover if you need to as well) -Rubber shift boot (may rip during removal) |
#7 |
My RB20 trans does the same thing. It's the output shaft bearing. Transmission out job and expensive if you don't do it yourself. Just buy a new (used) trans.
edit: it's harmless, get a louder exhaust if you dont like the noise :P If anyone asks, you have a dogbox. :P |
#8 | |
Curtis Edit: mine was the input shaft bearing not output shaft bearing. Last edited by c.f.169; 02-03-2011 at 06:38 PM.. Reason: input shaft bearing not output shaft bearing. |
#9 |
![]() Join Date: Jun 2004
a throwout bearing doesn't really do anything until you push in the clutch. if the noise goes away when you clutch in, chances are that it's not the TOB.
#10 | |
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
Why would it only whine in gears 1-3, but not 4th and 5th? I've had two S-chassis (S13/S14) with that exact transmission whine you're referring to. It definitely was NOT the throwout bearing. On the S13, we dropped the transmission, replaced the OEM clutch for an Exedy Stg 2 with a Fidanza flywheel, new TOB, and all seals. The wine was still there. We didn't replace the TOB hoping the noise would go away. We already knew the noise was coming from the transmission itself. |
#11 |
![]() Join Date: Nov 2006
Trader Rating: (54)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 54 reviews
Not a throwout bearing. It's more than likely an input shaft bearing. You need to open up the transmission and swap it out. Not something I'd recommend to someone who is unsure of what the problem is.
Call up a shop or a buddy who knows what he/she is doing. Search my posts and you'll see I've experienced this same issue. Left it alone for far to long and the bearing actually broke apart in my transmission. Metal bits came out when I drained the fluid. Didn't even bother with that transmission as more than likely something else would have been ruined and simply replaced it.
- Jimmy Wanted: TBD For Sale: TBD |
#12 | ||
#13 | |
The Architect.
Pick up a copy of the FSM and have a go at it. It's not expensive and in the end you'll have a "brand new" transmission that you won't have to worry about for years to come. |
#14 |
![]() Join Date: Sep 2008
If it makes the sound hes explaining about in neutral and it makes that sound thats a sign of the throw out unless like someone said its shafts bearing it self. My other car makes a wine in 3rd gear but doesn't do it in any other gears and its been that way for as long as ive owned it. and recently when i let off the clutch you can hear the throw out bearing making the noise and then pushing the clutch in you cant hear it. thats the main thing that says throw out bearing.
I would drain the tranny... check the oil and see if it looks out of the ordinary. Also low oil in trannys or rear diffs can cause winning .. could need more oil. before you drop the whole tranny just take half and hour out of your time and see what the oil looks like.
1994 toyota supra...... n-a D= 1992 nissan 240sx KA24E-T fully Built =D |
#15 | ||
I'm going to change the fluid on Saturday as a first step and go from there. Redline 75W-90, GL-4 2.4 liters is what it should be, right? |
#16 | |
thats what weight i used in mine. i just used the cheaper valvoline or what ever.
