Old 02-13-2011, 10:59 PM   #1
GeneStarWindGSW
GeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant future
Everyone too poor on zilvia to buy stuff
Well I'm leaving for the Miltary in April...soo all this stuff has to go or it might get tossed in the garbage.
You Contact me via PM, AIM: xxT88SupraT88xx , or text: 305-984-5103.
If I haven't gotten back to you and your still interested in anything, leave a message and I'll get back to you ASAP.If my inbox is full, leave me a visitors message.
(also if u have nothing good to say, just don't post..thank you)
I'll consider trades for parts below
V8 1UZ Swap
Traction Arms, Strut Bars, Tension Rod/Subframe/Door Brace, Etc
Motor/Tranny Mounts
Glovebox, Center Console, S14 Radio Bezel & s14 cut radio harness
Touchscreen 7" DIN
4-2-1 Header
Exhaust
B&M Short Shifter
Tires (205-235/35-40/17---255/35-40/17---225-255/40/18)
17" Wheels OR 18x9.5 Gunmetal MB battles OR baller wheels 17/18x10-11-12
Nissan PARTS FOR SALE/TRADE
  • KA/SR Shifter - $15
  • 240sx Frame Exhaust Heat Shield - $10
  • S13 Dead Pedal - $15
  • S13 Dash HUD - $25
  • KA24DE Injectors - $5 EA
  • KA24DE Crank Pulley - $40
  • S13 Red Valve Cover - $30
  • KA24DE Injectors /w round pinkle caps inside Rail /w FPR - $40
  • S13 KA24E Cut Tucked Engine Harness (ECU/Interior plug cut) - $20
  • KA24DE Oil Pan - $50
  • S13 Stock Rucas & Toe Rods - $15 A Set
  • KA24DE Bad Starters (Good for cores) - $15
  • S13 KA24DE Engine Harness (Cut interior Plug) - $30
  • S14 Toe/Rucas/Traction/RLCA & 5lug Knuckle - $15 EACH SET/ $20 for Knuckle
  • S14 Open Diff - $20
  • S14 Front Mudflaps - $30
  • S14 Charcoal Canister - $5
  • S14 6bolt Axles - $50
  • S14 Zenki Fog Delete - $30
  • S14 Horn - $20
  • SR20 T25 Oil/Coolant Turbo Lines - $30
  • SR20 Manifold - $70
  • SR20 Fuel rail - $10
  • SR20 T25 Elbow /w Gasket - $35
  • Incomplete Set of 240sx Peak Performance Poly Rear Subframe Inserts One is Torn - $15
  • DOHC Throttle Cable - $30
  • S14 Stock Clarion Amp - $30
  • S13 Radio Brackets (L/R) - $30
  • 180sx bumper turn signal (RIGHT) - $50
  • Z32 E-Brake Cables for S13 - $100
  • AEM EMS for S13 89-94 KA (in the box) - $1000
  • M/T ka flywheel bolts - $45
  • S14 to S13 KA Adapter harness - $80 {needs to be soldered}
Toyota PARTS FOR SALE/TRADE
  1. 1JZ/2JZ ARP rod bolts - $65
  2. 7m Blockoff Plate - $10
  3. Magnetic Drain plug for R154 Transmission - $15
  4. 1JZ/2JZ TTC Fan Pulley Cover - $60
  5. 1JZ/2JZ Thermostat Housing Rotator plate- $55
  6. R154 Throwout Bearing - $20
  7. R154 Clutch Hub bearing - $45
  8. 1JZ/2JZ Stock Oil Filter housing /w dual -10AN fittings - $100
  • R154 used Slave cylinder & hardline - $20
  • R154 Clutch Fork - $55
  • 2JZ-GE EGR Delete /w Gasket - $15
  • MR2 Manual Steering Rack - $30
  • Toyota Emblems - $2 EA
  • Cressida Rear Driveshaft Piece - $10
  • JZX81 Cressida mounts/brackets - $250
  • Cressida RHD Swap - $600
Wheels FOR SALE
  • (Pair) 18x8.5 Zenetti Vega wheels (5x114.3)(Bad Tires) - $150
  • (4) 18x8.5 Zenetti mystic wheels (brand new cooper 215/35/18 tires) (5x100) - $400
  • (Pair) 17x9 +30 Gunmetal MB battles /w Bald/Crap tires (5x114.3) (205/40/17) - $350
GeneStarWindGSW is offline
