09-21-2003, 08:08 PM | #1 |
wheels wheels and wheels
How would 18*8.0 rim with a +20 offset look? car is a s14 with eibach sportlines.. how about tire sizes..I want staggered/and mabie stretched but these aint wide enough..what you guys think??????
this is the only decent size ive found with the racing hart c4 |
09-21-2003, 08:31 PM | #3 |
Retired General
When deciding wheel widths, imo, it should be: for 15s - 15x7 or wider for 16s - 16x8 or wider for 17s - 17x9 or wider for 18s - 18x9 or wider Last edited by revat619; 09-21-2003 at 08:34 PM.. |
09-21-2003, 08:56 PM | #5 |
ok cool, so i should look for something like 9in in the front and 9.5 or 10in in the back? with what offset and tires?I definitley want a staggered stance tho...
09-22-2003, 01:26 AM | #6 | |
Junkie
-Juan |
09-22-2003, 03:22 AM | #8 | |
Retired General
For example, a 15x7 doesnt look that narrow, but an 18x7 looks more narrow to the eye because of the increase in height (diameter). Like a square and a rectangle. They can be the exact same width, but the rectangle appears "skinny" because of its height. As you can see, its mostly about appearance. I think an 18x7 looks weird, but some people may not. I'm not trying to say a certain size is the "right size", i'm just stating what i believe to be a good balance between wheel diameter and wheel width. |
09-22-2003, 07:46 AM | #9 |
WOW addicted
If your not Turbo, then those 18x9's will sap a ton of power. going from the stock wheels to 17x9's felt like I lost about 10hp. The 18's would be quite a bit worse.
09-22-2003, 04:36 PM | #11 |
sykikchimp i just bought a front clip so Im not gonna be NA for long..you got 17 by 9 all around? whats the widest you can go front and rear with out flares or rolled fenders? what size tires do you have?
09-22-2003, 04:38 PM | #12 | |
09-22-2003, 06:01 PM | #15 |
+30 with 235/45 or 245/40 and less than 2.5 degrees should be pretty flush, and with lots of camber and or a stretched tire (225 or 215) +20 should also be a good bet for flushness imo. It will fit front and rear (most likely) as well, no matter what suspension you have.
