Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Drivetrain
Old 02-25-2011, 11:29 AM   #1
FBNISSAN
FBNISSAN's Avatar
FBNISSAN is an unknown quantity at this point
Act flyweels-I Like It!!!
Please send me a PM for your order.
Part #:600225 ($259 + shipping)
ACT XACT StreetLite Lightweight Flywheel for S13 S14 SR20DET. Weighing in about 14.1lbs, this low-inertia and lightweight flywheel is a big contender in performance and function. The one-piece design from hot forging chrome-moly steel, gives ultra fine centralized grain structure for superior strength and efficient uniform heat transfer. Each flywheel is made with precision and high tolerances using CAD and FEA (finite element analysis) methods to produce a flywheel that yields the best results to meet many legal racing standards such as SFI Specifications 1.1. The integral ring gear is part of the one-piece design to prevent any sort of separation during high RPM's and it allows more weight reduction at the outer area of the flywheel which provides very low inertia resistance. All flywheels are CNC machined with digital computer balancing for a super smooth operation and reliability.
Specs:
Weight: ~14.1 lb
SFI Specs 1.1
Chrome-moly Steel
CNC machined
ONE-Piece
Lowest inertia
Vehicle Applications
1989 - 1998 Nissan 180SX (S13) L4 2.0L SR20DET
1989 - 1994 Nissan Silvia (S13) L4 2.0L SR20DET
1995 - 1998 Nissan Silvia (S14) L4 2.0L SR20DET
Part #:600230 ($279 + shipping)
ACT XACT ProLite Lightweight Flywheel for S13 S14 SR20DET. Weighing in about 10.5lbs, this low-inertia and lightweight flywheel is a big contender in performance and function. The one-piece design from hot forging chrome-moly steel, gives ultra fine centralized grain structure for superior strength and efficient uniform heat transfer. Each flywheel is made with precision and high tolerances using CAD and FEA (finite element analysis) methods to produce a flywheel that yields the best results to meet many legal racing standards such as SFI Specifications 1.1. The integral ring gear is part of the one-piece design to prevent any sort of separation during high RPM's and it allows more weight reduction at the outer area of the flywheel which provides very low inertia resistance. All flywheels are CNC machined with digital computer balancing for a super smooth operation and reliability.
Specs:
Weight: ~10.5 lb
SFI Specs 1.1
Chrome-moly Steel
CNC machined
ONE-Piece
Lowest inertia
1989 - 1998 Nissan 180SX (S13) L4 2.0L SR20DET None
1989 - 1994 Nissan Silvia (S13) L4 2.0L SR20DET None
1995 - 1998 Nissan Silvia (S14) L4 2.0L SR20DET None
Part #:600360 ($254 + shipping)
Most stock flywheels are heavy cast iron and are designed for optimum driveability by storing some of the engine’s power in the form of inertia. Light flywheels provide significantly improved engine response and acceleration without compromising driveability. XACT flywheels are designed for improved engine sponse, strength and affordability.
PROLITE
* Lighter ACT Flywheel
* Best throttle response, lowest inertia
* Super rigid, precision made and dynamically balanced
* Recommended for road and rally racing
* Weight 10.00 lbs
1991 - 1994 NISSAN 240SX L4 2.4 GAS FI N KA24DE
1995 - 1998 NISSAN 240SX L4 2.4 GAS FI N KA24DE
1989 - 1990 NISSAN 240SX L4 2.4 GAS FI N KA24E
Email:[email protected]
Website:fredbeansparts.com
Phone#877-872-6606
FBNISSAN is offline
Old 02-25-2011, 04:50 PM   #2
didderson
didderson's Avatar
didderson will become famous soon enoughdidderson will become famous soon enoughdidderson will become famous soon enoughdidderson will become famous soon enough
Send a message via AIM to didderson
Do you have a larger or more real life photo of the SR20 streetlite flywheel?
I'll search the googs if not heh.
didderson is offline
Old 02-26-2011, 05:38 PM   #3
FBNISSAN
FBNISSAN's Avatar
Closed!
The number 3 rule.
Phone#877-872-6606
FBNISSAN is offline
