Old 03-04-2011, 03:50 PM   #1
KOUKI_VERS13
Trader Rating: (18)
KOUKI_VERS13 is an unknown quantity at this point
Feedback Score: 18 reviews
FS: S13 KA/SR Parts..............
Shipping will be via USPS Priority Mail Flat Rate Box, ranging fom $4-15 anywhere in the US. Insurance is extra and reccomended. Payment by Paypal only, please.
PICTURES BELOW..
SOHC KA Parts..
(All parts were taken off of a low mileage (60K miles) KA.)
-Starter, very good condition. $50
-A/C compressor, no leaks. $60
-Fairly new set of injector seals, full set. $20
-Fairly new OEM fuel filter. $10
-Front parking lamp lens, only one. $5
-Radiator brackets, SOOOOOOOOOLD
-Tachometer, very good condition. $15
-Fuel pump $45
-ECU (Auto, #11) $35
-Ignition coil $25
-Stock RUCA's, bushings are in good condition. $30
-Stock toe arms, " ". $25
-Stock traction arms, " ". $20
-Stock tension rods, one rod's bushing has a small tear/leak, the other is fine $15
Sr Parts/Misc..
-Exhaust gaskets..
1- 2 1/2" exhaust pipe gasket $5
3- 3" exhaust pipe gaskets $10 each
1- manifold to turbo gasket (t25/t28) $10
1- 3" downpipe gasket $10
-Brand new ACT pilot bushing. $10
-Stock SR alternator pulley $10
-Brand new OEM KA/SR shifter bushing SOOOOOOLD
-Used pressure plate bolts, all there. SOOOOOOLD
-Kics Project (4x114) 15mm spacers. SOOOOOOOOLD
-Brand new KA/SR throwout bearing. SOOOOOOOOOOLD
-Brand new 42 Draft Designs oil catch can with internal baffling/drain plug in wrinkle black finish (powdercoat). Takes 3/4"ID tubing. $95
-Brand new Earls 90 degree and 45 degree fitting, both are NPT to barb (1/4" to 1/8") $15 each
-KA/SR aluminum shifter bushing, this replaces the stock plastic piece that breaks down over time. Also gives a more direct feel. SOOOOOOOOOOOLD
-Brand new DOHC power steering return line $20
-Brand new Greddy radiator hose tap for temperature sensor. SOOOOOOLD
-Brand new Greddy oil temperature sensor adapter (M12x1.25). Replaces stock drain bolt and has port for threading in oil temp sensor. $15
-Brand new Nismo bleeder for clutch dampener system. $10
-Brand new exhaust manifold wrap kit (grey & 2"x25'), with metal locking ties. Enough to wrap a 4 cyl. manifold. $70
-Brand new Greddy silicone coupler for Z32 MAF (80mm). $10
-Used Greddy silicone couplers $4 each
-Pair of Eclipse 4x6 co-axials, good condition. $35
-Five brand new S13 front hub bolts. $12 for all.
-(1) Brand new S13 SR oil squirter, mounts in block, below pistons. $25
KOUKI_VERS13 is offline   Reply With Quote
