Old 03-15-2011, 01:57 PM   #1
SRnewbie
SRnewbie is an unknown quantity at this point
another sr knocking problem
installed an s13 sr20det into my s14, got it to start no problem, but there is a constant knocking at idle and gets faster and loudler to redline. thought it was the timing chain guides or loose chain. so i bought a compete timing chain kit from frsport. jus got done putting that in. (it was bitch by the way). and the knocking is still the there??? waht could it be??
also: rebuild the head while off new spings, retainners, valve guide, and valve guide seals. and yes i did bleed the lifters correctly
also: replaced oil pump head gasket and now use apr head
the knocking sounda lik it coming from the head . . .but waht do i kno . . ??
where is it coming from?? pls help?
SRnewbie is offline   Reply With Quote
Old 03-15-2011, 02:43 PM   #2
Leetfade
Leetfade's Avatar
Leetfade is an unknown quantity at this point
The noise I've been getting is actually coming from the rocker arms but it's more of a ticking. Check those for any dents, grooves, etc.
Also check your turbo and make sure it hasn't had the back screws back out. Also check the exhaust to make sure it's not loose anywhere. I've heard of that creating this same noise.
Leetfade is offline   Reply With Quote
Old 03-15-2011, 11:29 PM   #3
gzer750
gzer750's Avatar
gzer750 is an unknown quantity at this point
is it the metal chain cover?
gzer750 is offline   Reply With Quote
Old 03-16-2011, 10:33 AM   #4
SRnewbie
thax, but ive already tried taking off the that top plate. knocking is stil there . . .
Old 03-16-2011, 01:26 PM   #5
statickx991
statickx991 is an unknown quantity at this point
any way you can post a video of it running.
im a f18 bro
statickx991 is offline   Reply With Quote
Old 03-16-2011, 02:10 PM   #6
SRnewbie
yea i can do that. it will up soon.
Old 03-16-2011, 03:27 PM   #7
SRnewbie
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/4qj-DVY0ses?hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/4qj-DVY0ses?hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old 03-16-2011, 03:30 PM   #8
SRnewbie
<iframe title="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/4qj-DVY0ses" frameborder="0" allowfullscreen></iframe>
Old 03-16-2011, 03:34 PM   #9
SRnewbie
http://www.youtube.com/watch?v=<iframe title="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/4qj-DVY0ses" frameborder="0" allowfullscreen></iframe>
Old 03-16-2011, 10:24 PM   #10
statickx991
id hate to say this cause that engine is clean but to me just from the video it sounds like a spun bearing (rod knock) i could be wrong, but it seemed to fast of a knocking to be a lifter or something. good thing is it didnt let loose and go out the side of the block. so maybe it would be nice you can refresh the engine now some new rings and seals and hone it out. but thats my opinion
im a f18 bro
