Old 03-22-2011, 03:13 PM   #1
driftfreek
driftfreek is on the path to ruindriftfreek is on the path to ruin
Send a message via AIM to driftfreek Send a message via MSN to driftfreek
ka24de runs nicer with 91 but still loses power
Hi guys, i dont know much about how to diagnose problems so im reaching out for your help.i have a problem with my ka24de. when i used 87 octance my engine would not rev smooth. at wot it lose power for a quick instant, then keep climbing up the rpms then lose power again, then keep climbing, etc. it would lose power 3 to 4 times before i need to shift( at 5800rpms). then i switched to 91 octane and it would run smoother and would only lose power ONCE at high rpms. i tested my tps sensor and its good. what should i do to fix this? whats causing this to happen?
driftfreek is offline   Reply With Quote
Old 03-22-2011, 03:30 PM   #2
Pandapants
Pandapants's Avatar
Pandapants is an unknown quantity at this point
Send a message via AIM to Pandapants
what kind of fuel pump, wires, plugs, and gap are you running?
Pandapants is offline   Reply With Quote
Old 03-22-2011, 03:33 PM   #3
driftfreek
gap is oem. pump is oem. plugs are ngk and wires are aftermarket(cant remember the name). but none of those i changed when i when from 87 to 91.
Old 03-22-2011, 05:48 PM   #4
1337
1337's Avatar
1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection1337 is close to perfection
Send a message via AIM to 1337
check your timing
1337 is offline   Reply With Quote
Old 03-23-2011, 12:41 PM   #5
g00se
g00se's Avatar
g00se is an unknown quantity at this point
octane would'nt matter if theres a problem, check spark (may have to replace plugs wires cap if its been a while) Fuel (filter, pump, check for leaks at the injectors)
any CELs?
g00se is offline   Reply With Quote
Old 03-23-2011, 06:09 PM   #6
Nick_04K
Nick_04K's Avatar
Nick_04K is an unknown quantity at this point
Originally Posted by 1337 View Post
check your timing
Bingo
msglength
Nick_04K is offline   Reply With Quote
Old 03-23-2011, 09:12 PM   #7
napz510
napz510's Avatar
Trader Rating: (36)
napz510 is an unknown quantity at this point
Feedback Score: 36 reviews
Possible fuel pump...check on it or if you have spare replace it..
napz510 is offline   Reply With Quote
Old 03-23-2011, 09:21 PM   #8
lenox_240
lenox_240's Avatar
lenox_240 is an unknown quantity at this point
check your timing
^^^ i agree
lenox_240 is offline   Reply With Quote
Old 03-23-2011, 09:29 PM   #9
statickx991
statickx991 is an unknown quantity at this point
id say timing deff and is ur ecu chipped or anything?
im a f18 bro
statickx991 is offline   Reply With Quote
Old 03-23-2011, 10:35 PM   #10
1337
1337's Avatar
