Old 03-25-2011, 04:09 PM   #1
greenman100
Trader Rating: (18)
greenman100 is an unknown quantity at this point
Feedback Score: 18 reviews
DEFI, Topmount SR mani, MAFs, ARP rod bolts, CAS, etc
All parts located in Gainesvile, FL. I regularly visit Orlando and Tampa though, and can deliver the parts after a deposit has been made via PayPal.
Pictured:
T3 or T4 topmount ramhorn manifold, braced runners and no cracks. Flange works for T3 or T4 turbos. 38mm wastegate. - $150
DEFI BF boost gauge, with sensor. reads in PSI. $150
DEFI BF EGT gauge, without sensor, reads in degF. $80
Full set of DEFi gauges with sensors, control unit, and seven 60mm gauge pod - Boost, EGT, Oil press, Oil temp, Water temp, Fuel press. All sensors are loomed and protected. With fiberglass molded gauge housing, $1000
Aftermarket Fog Lights, used - $20/pair
Z32 MAF, $80 each ONE LEFT.
ARP Rod Bolt kit - $40
Timing Light - $25
SR20 CAS - $100
SR20 OEM pulley set - $20
3" Test Pipe - $30
Not Pictured:
S13 SR Exhaust cam - $10
Window motor - $10
S14 door handle - $10
S13 SR Alternator - $50
S14 ignition lock w/key, you will need to save the non-keyed half of the assembly, i cut mine to get it off. - $10
S14 ignition switch, uncut pigtail - $10
OEM SR20 HG, never used - $20
S13 Speed Sensor - $25
greenman100 is offline   Reply With Quote
