Old 03-29-2011, 03:05 PM   #1
Josho
Josho's Avatar
Josho is an unknown quantity at this point
Blacktop running rich/poor after upgrades
Ok here's the situation.. I have a 93 Nissan Silvia originally equipped with a redtop sr20det. The car ran perfect stock. Now I have a s13 Blacktop with a built head, gt2871r turbo, walbro 255, stock injectors, maf and a stock Blacktop ecu. Now obviously the car would run a little rough but it's still driveable. The only problem it gives me is every now and then it'll shut off when I let off the gas and come to a stop.
Ok, so when I purchased the blacktop(already built) I also bought this guys tuned ecu. He had it tuned for the same mods including the turbo. They only mods I was missing was the z32 maf and 850cc injectors(which his ecu was tuned for as well). So I bought a new maf and injectors and installed them and the tuned ecu. With that installed the car cranks up just fine but rins very rough. I can rev it up as high as I want but it breaks up real bad. I swapped my maf with a known good one and it runs the same.. Any suggestions? Could the ecu be bad? I also have a coolant temp sensor out of a redtop, not sure if that matters.
Josho is offline   Reply With Quote
