Old 03-29-2011, 11:00 PM   #1
qwarnon
qwarnon has a spectacular aura aboutqwarnon has a spectacular aura aboutqwarnon has a spectacular aura aboutqwarnon has a spectacular aura aboutqwarnon has a spectacular aura aboutqwarnon has a spectacular aura about
Parting out the v8 s13 coupe
Ok, well after many long years of slowly working on this project, i've realized, I 1) can't afford to get it done, and 2) don't have the time.
That being said none of these parts have much use on them at all. I broke the engine in, but never even moved the car more than down the street afterwards.
Ok, no trades, unless they are highly in my favor
I will ship anywhere at your expense
Engine - $1500 complete
1969 350 4 bolt main block bored to 355
Brand new rotating assembly
edelbrock 750cfm carb
keith black flattop pistons
arp bolts
summit 1106 cam
cloyes double roller timing gears and chain
air gap dual plane intake
461 heads ported and shaved with 1.6 roller tip rockers and 2.02/1.60 valves
mini starter
underdrive
custom oil pan
alternator
high flow water pump
power steering pump
all felpro gaskets
I will part out the carb, or top end/bottom end.
I also have a mckinney motorsports mount kit to put this motor in your s13. Id take $75 for this. paid $300
Next I have a t56 6 speed transmission for an ls1
It's got about 3 miles on a brand new rebuild, ill open it up and show you if you like, it looks spotless.
I'd take $950 for the tranny
I've got an adapter plate to bolt the tranny to a gen 1 sbc I'd take $75 for.
Ram 900 series powergrip HD clutch - $175
billet steel lightened flywheel for sbc - $100
240sx parts!!!:
again, these parts have maybe moved 1 mile.
Megan track coilovers $750
aftermarket tie rods and ends, dont remember brand - $75
aftermarket rear upper control arms - $75
aftermarket tension rods -60
fender braces -80
brand new 300zx 30mm calipers - $75 per caliper or $125 for both, with brand new pads.
300zx conversion lines $40
brand new 300zx drilled and slotted rotors front - $75
rear slotted and drilled rotors - $50
300zx master cylinder, ready to install!!! - $100
CNC clutch pedal and slave cylinder - $75
EXCELLENT BLACK DASH - $125
Wheels:
sportmax 006 17x9 in back 17x8 in front $400
with current tires, not much tread left
Tires: I have 3 225/45/17 Pirelli P zero tires I'd take $60 a piece for em.
Fuel cell, 10 gallons, - $65
Poly racing seats with sliders and good covers - $100
PHOTOS are in this album:
http://s11.photobucket.com/albums/a1...%20part%20out/
As I think of new things i will post them, If you want any parts i didnt list, let me know i may have them
Email me at [email protected], or text me at 573 576 1114 for a Much faster response
qwarnon is offline   Reply With Quote
