Old 10-08-2003, 11:41 PM   #1
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
T3 vs. S14 T28
ok..its a T3 .60/.48(i have the T3 now)
S14 T28...not sure....60/.62??
i have an SR(S13) on the way with a S14 T28 on it.
which is better?? (250rwhp..i guess) i jus wanna know which is better over all. like lag, flow, max psi...all that good crap.
sell the T3 or keep it??
i know i made a similar thread...but this is for an SR.
T28 Turbo specs:
Compressor: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing
Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing.
Center Section: Ball Bearing
...idk
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 10-11-2003, 10:33 AM   #2
Muzzy
Muzzy's Avatar
O
lemme have a dollar
Old 10-12-2003, 04:29 AM   #3
rednerd
rednerd is an unknown quantity at this point
I can't vouch for the meritts of the individual turbo, but I do know that the T-3 won't fit on the stock t-25 manifold. The square flange on the t-3 is bigger. Everyone who goes with a t3/t4 setup top mounts the turbo because of the size of the t4 compressor housing.
According to Enjuku racing, the s14 t-28 is probably the best street turbo going but don't expect super high HP numbers out of it. I was told 300HP is the max with injectors, cams and tuning.
Good luck. If you decide to try the t3, I have a stainless header that is cracked around the t-25 flange. I'd sell it pretty cheap. You could then have a t-3 flange welded on to see if the t-3 will fit.
rednerd is offline   Reply With Quote
Old 10-12-2003, 09:23 PM   #4
Muzzy
Muzzy's Avatar
thanks for the response
but manifold is not the issue really. i know there is a difference in flanges..but head to head which is better over all??
lemme have a dollar
Old 10-12-2003, 10:57 PM   #5
Pudula
Pudula is on a distinguished road
Send a message via AIM to Pudula
Depends on the intended purpose. For me, I want a street car with a broad power band so I have a garrett gt2871r which can put out 400hp and still spools like a mofo. If you want really high numbers for drag racing, get a t3/t4.
Ryan
Pudula is offline   Reply With Quote
Old 10-12-2003, 11:19 PM   #6
DuffMan
DuffMan's Avatar
DuffMan is an unknown quantity at this point
Send a message via Yahoo to DuffMan
The T3 and T28 are pretty much identical in performance. I think a .64 a/r t25 and .48 T3 exhuast housing would be close in flow capacity, and the compressors are very similar.
So if manifolds arent the issue, I wouldnt get a t28, unless you really want the increase in response with a ball bearing turbo. T3 will still spool quickly.
DuffMan is offline   Reply With Quote
Old 10-12-2003, 11:43 PM   #7
Muzzy
Muzzy's Avatar
well i have both now...jus a matter of which one to keep.
i dont plan on doin too much to my motor as of yet...cams and thas about it 4 now (on 370s and stock pump..should upgrade to walbro huh?)...then upgrade fuel probobly when i wanna run higher boost like 12+
lemme have a dollar
Old 10-12-2003, 11:49 PM   #8
DuffMan
DuffMan's Avatar
Well the T28 would sell for a lot more $$
Old 10-12-2003, 11:53 PM   #9
Muzzy
Muzzy's Avatar
lol tru..almost double..maybe
lemme have a dollar
Old 10-13-2003, 12:38 PM   #10
Pudula
Yeah, paid $1310 for my garrett...add an "hks" embossing on it and expect to pay 2000+
Old 10-13-2003, 02:11 PM   #11
Muzzy
Muzzy's Avatar
also tru....but..Y???
is it cuz the T28 is BB?? (probobly)
lemme have a dollar
