Old 04-20-2011, 03:40 PM   #1
HellaSexyS13
HellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-known
s13 Trouble Shooting Brake Problem
so i installed the 300zx brakes (front and rear) on my s13 coupe, also installed the 300zx master cylinder.
i go to put brake fluid in the system today and it sucks a little in and then stops and the pedal still feels soft. i kept pumping the pedal but nothing happened, i also opened the bleeder valves on each caliper and nothing came out.
what could the problem be? a faulty master cylinder? a clog?
any help would be great thanks
HellaSexyS13 is offline   Reply With Quote
Old 04-20-2011, 05:07 PM   #2
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
I would check the master cylinder first. Put your old one back in and see if that works.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 04-20-2011, 05:18 PM   #3
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
How are you bleeding the brakes?
Is there any brake fluid leaking anywhere?
zombiewolf513 is offline   Reply With Quote
Old 04-21-2011, 12:13 PM   #4
HellaSexyS13
nothing is leaking, the brake lines wouldnt even fill up, i was told i need to bleed the master cylinder first so im gonna try that.
Old 04-21-2011, 12:15 PM   #5
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
yes you should bench bleed the master first then install and bleed the entire system
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
300zx, brakes, calipers, fluid, s13
